08-28-2020, 07:15 AM | #1 |
Inductive tach
Amazon has a Runleader inductive tach for $13. The hook up seems easy especially for a flathead. Has anyone had any experience with one?
Thanks Tom |
08-28-2020, 07:41 AM | #2 |
Re: Inductive tach
Used a similar one on a lawn tractor. It just had a wire that wrapped around a plug wire for the signal.
Unless you can determine it will work on an 8 cyl. engine, I would be suspect of it's capability to do so.
08-28-2020, 08:48 AM | #3 |
Re: Inductive tach
I had a Cirello magneto on the hemi in my race car. It wouldn't run a regular tach, so got one of those inductive senders and a very cheap digital tach from J.C. Whitney. I don't think the whole setup was even $50. It worked fine. I later got a magneto-specific sending unit from Autometer and hooked up a regular "4-wire" Mallory tachometer. The units read very close to each other.
The hemi, of course, had eight cylinders. These things will work on any 4-cycle engine from 1 to 28 cylinders because each individual cylinder only fires once every two revolutions. Well, their are some engines with "wasted spark" ignition systems, but I think we can ignore them here. And there goes my 6 volt tach driver business. |
08-28-2020, 10:52 AM | #4 | |
Re: Inductive tach
Nope, looks like they even take care of the number of cycles. Runleader is proud to present the new RL-HM035LT LED Digital Multifunction Temp meter Tach/Hour meter. It can work on any 2 or 4 stroke gas engine up to 16 cylinders, 9 engine type setting. It has a powerful Temp system, RPM measuring system,timing system, as well as some other unique function design. Last edited by JSeery; 08-28-2020 at 10:58 AM. |
08-28-2020, 11:02 AM | #5 |
Re: Inductive tach
08-28-2020, 11:08 AM | #6 |
Re: Inductive tach
09-01-2020, 05:29 PM | #7 |
Re: Inductive tach
Well, gave one a try and ended up finessing it to get close to accurate reading.
Set it up for 8cyl 4 stroke reading as directed and got about half the RPM reading I should have compared to the reading on my timing light. Played with the settings till I got close to what the timing light was reading for idle RPM and ended up on 4cyl 4 stroke setting. Reasonably accurate through several throttle settings. This, on a 59AB with crab dual point dizzy 1947 vintage. Any speculation as to why the 4cyl setting vs the 8cyl was more accurate??
Aim low--achieve your goals. |
09-01-2020, 07:31 PM | #8 | |
Re: Inductive tach
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-02-2020 at 02:11 AM. |
09-01-2020, 11:00 PM | #9 |
Re: Inductive tach
Hi; My British vehicles had tachs that used a single coil of wire on the back of the tach. Found those in MGB and some British military vehicles. the tach sensed ign pulses or current in that single loop of wire. Newc
09-02-2020, 05:38 PM | #10 | |
Re: Inductive tach
09-02-2020, 06:29 PM | #11 |
Re: Inductive tach
No. 8 plug wire closest to firewall driver's side (if I have my numbering right)
09-02-2020, 10:10 PM | #12 |
Re: Inductive tach
So I am curious, how accurate is “reasonably accurate”. Were you able to verify your readings with another source? Do you think attaching the sensor on the #1 cylinder would make a difference? They sound like a good option for those who just want to monitor the RPMs going down the road.
09-03-2020, 10:48 AM | #13 |
Re: Inductive tach
^ That would be good to know.
Used to see these types of tachs years ago on lawnmower engines, usually in gocarts. |
09-03-2020, 05:39 PM | #14 | |
Re: Inductive tach
