Old 02-08-2015, 09:05 PM   #1
David Williams
Default Ignition Abnormality
Had a weird thing happen today, I was troubleshooting my ignition system. First, the truck has sit since late fall in my farm shop, was going to bring it over to my basement shop for some work. When it wouldn't fire, I checked fuel,OK then went to ignition. With coil wire loose and closing open points with screwdriver to check for spark to a head bolt, the starter actually kicked,l saw the fan move. Couldn't believe it tried again same thing. Distributor has been rebuilt,along with engine,starter. I did have a hot spark. Am I having a ground issue between distributor and block? Truck ran and started fine til I put it up for winter. Any thoughts. Ghost in my shop.
David Williams is offline   Reply With Quote
Old 02-08-2015, 09:57 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Ignition Abnormality
I had a similar problem 3 years ago after not being driven for 4 months during the monsoon season. Even after cleaning the points it didn't fire up until I tried the hand crank. It fired right up with one pull of the crank. Once fired up it was fine the rest of the summer.
Old 02-08-2015, 09:59 PM   #3
WestCoast
check for cross firing , maybe a cracked dist cap, or a carbon track inside the dist cap
WestCoast is offline   Reply With Quote
Old 02-08-2015, 11:30 PM   #4
daveymc29
daveymc29's Avatar
Ever turn your key to the "on" position and find that the engine was now running? I have done that twice with a Model A. Glad I make a habit of putting the shifter into neutral, hand brake on and the clutch in whenever I start these machines.
daveymc29 is offline   Reply With Quote
Old 02-08-2015, 11:55 PM   #5
pat in Santa Cruz
pat in Santa Cruz's Avatar
it could be the battery is low, or the battery ground is poor, so the starter sucks up so much battery that there is not enough to spark. Then when you activate the points or hand crank it, it has enough juice to spark
pat in Santa Cruz is offline   Reply With Quote
Old 02-08-2015, 11:57 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by pat in Santa Cruz View Post
it could be the battery is low, or the battery ground is poor, so the starter sucks up so much battery that there is not enough to spark. Than when you activate the points or hand crank it, it has enough juice to spark
Something to look at.
Old 02-09-2015, 09:49 AM   #7
1930artdeco
1930artdeco's Avatar
Somehow I think your starter switch is somehow sticking, even though you did not touch it. Sounds interesting though.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-09-2015, 11:11 AM   #8
Mitch//pa
it sounds like when you energized the points it combusted some gas in one of the cylinders
