11-13-2017, 10:08 AM | #1 |
3 point seat belts
I am planning on using the original seat bench and would like to install 3 point seat belts on my 51 F1.
My concern is properly installing a shoulder strap mount on the cab. Looks like there are a few different mounts that are being manufactured for this. Any recommendations? I would prefer not to get involved with welding the mount if possible. |
11-13-2017, 11:13 AM | #2 |
Re: 3 point seat belts
This is not an F1, but a Chevy of similar vintage. Maybe it will be some help?
http://www.julianos.com/Articles.asp?ID=277 |
11-13-2017, 11:38 AM | #3 |
Second the Julianos. Give them a call.
Got'em in my Merc. and they are installed virtually the same way. Afraid that you may have to do some welding unless you can figure out a suitable way to mount them.
11-13-2017, 12:15 PM | #4 |
I third the above answers. Go straight to Julianos for the belt set up and accept the fact you will need some welding. You will be very happy when it is done.
My 40 PU has this set up, the reel assembly fits perfect down in the cab corner. My opinion (and others). |
11-14-2017, 08:52 AM | #5 |
I got a kit for my F-1 and it was easy to install. There are braces above and below the rear window that span the width of the cab. It required welding a piece between the braces. Cab modification was not required. Picture of similar setup in Mid-Fifties catalog for '53 pickup. Here is a picture of one installed. You can see the brace under the window.
11-14-2017, 10:22 AM | #6 |
11-14-2017, 01:42 PM | #7 |
Here is a pic of my 40 with the already mentioned Julianos seat belt setup. The upper bracket is welded in before painting. It is hard to see ,but it is visible on the passenger side. It is at the level of the upper rubber bumper. Makes a very neat installation since the reel drops into the cab corner and has options to secure it. I recommend the hardware kit from Jullianos as the backing plates are way better than the crummy washers from the cheap guys. Or you can make them.
11-14-2017, 01:52 PM | #8 | |
11-14-2017, 02:07 PM | #9 | |
FYI: Sit in the truck to locate the upper mount so the shoulder belt fits you as best it can. Too low and it will catch you in the neck. Too high and it may not hold you as well when you need it most. I don't know about your truck but in the older ones the door post is close to the seat back. This puts the belt mount a little more forward than I think is optimal but its way better than nothing. |
11-14-2017, 04:07 PM | #10 |
Actually the reason for the picture is to show that the big bulky reel is nowhere to be seen, even with the seat removed.
11-16-2017, 02:39 AM | #11 | |
11-16-2017, 08:17 AM | #12 |
