Old 07-18-2010, 05:11 PM   #1
Ice man
Ice man's Avatar
Default School Me, Please
OK down through the years I've done just about every thing on a Model A. Well now I got a shifter lever thats to go in an old trany housing, and as you well know, (that spring) is not easy. Got any ideas, I ran out of memory, of what I thought I heard yrs ago, to do it the easy way. HELP. Iceman
Ice man is offline   Reply With Quote
Old 07-18-2010, 06:50 PM   #2
fordfixer
Default Re: School Me, Please
I put the spring in a vise and close it up. Then tie it with mechnics wire, three separate times, evenly spaced. Install keepers and the clip the wires and pull out with needle nose pliers.
fordfixer is offline   Reply With Quote
Old 07-18-2010, 07:04 PM   #3
cannon
insert a wooden dowl into the spring before trying to close it up. takes a little thought to close the spring with the dowl installed, can be done, THEN wire it up with mechanics wire three ways -continue with fordfixer ideas.
cannon is offline   Reply With Quote
Old 07-18-2010, 07:06 PM   #4
Logan
Logan's Avatar
If you have an old file, the ones that are about a foot long and an inch wide, that come to a point on one end, you can use a torch and bend the pointed end like a z. this will give you the leverage you need to press the spring down far enough, and it will not slip off the end as long as when your pressing down you keep it strait up and down. Another good idea is to put duct tape around the file part so you dont tear up your hands.
Cowtown A's
Logan is offline   Reply With Quote
Old 07-18-2010, 07:20 PM   #5
ford1
i made a T handle tool with a big heavy washer welded on the shaft end, i cut part of the washer off so it looked like a "C" im pretty heavy so all i had to do was lean of the tee handle part of the tool and compress the spring to remove the clip
ford1 is offline   Reply With Quote
Old 07-18-2010, 08:27 PM   #6
Doug in NJ
Doug in NJ's Avatar
The compress-in-a-vice-and-hold-with-wire trick worked fine for me, on the first try. I used a full face guard during the process.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 07-18-2010, 08:44 PM   #7
Ice man
Ice man's Avatar
Thanks guys, I tried the wire thing and it was a frig, I think I will get the tool and do it so I don't loose any thing. Iceman
Old 07-18-2010, 10:09 PM   #8
JoeWay
JoeWay's Avatar
Check this link on Vince Falter's page for an excellent, easy-to-make tool:
http://www.fordgarage.com/pages/shiftlevertool.htm
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 07-18-2010, 10:44 PM   #9
sonny30coupe
I used a similar tool that I made from the drawing on Vinces site, took me 10 minutes to do out of a free piece of pipe and a washer, cut the piece out of the washer and and a slot in the pipe after removing some of the side of the pipe and it took 10 seconds to get the spring and I still have all of my teeth. That wire thing is a bad idea.
sonny30coupe is offline   Reply With Quote
