Old 12-22-2015, 01:26 PM   #1
bk53
Default another gas filler neck question. 53 f100
I replaced the gas tank and am having a devil of a time getting the tank and the filler neck pressed inside the hose. I've tried to grease it, oil it, silicone it.
Right now the hose is on the tank and clamped. Seems like no way I'll get this filler neck in this way. I already tried it the other way around. Which way has anyone had the most luck with?
Thanks,
Bill
8ba 276 dual 97s navarro heads
bk53 is offline   Reply With Quote
Old 12-22-2015, 02:23 PM   #2
V12Bill
V12Bill's Avatar
Default Re: another gas filler neck question. 53 f100
Gas neck to tank hoses are a tight fit .If you have the wrong size it is even tighter. Check to be sure you have the correct size hose.
V12Bill is offline   Reply With Quote
Old 12-22-2015, 02:26 PM   #3
wbedwards
wbedwards's Avatar
have you tried heating the end of it in hot water?
wbedwards is offline   Reply With Quote
Old 12-22-2015, 02:29 PM   #4
Lawson Cox
Lawson Cox's Avatar
Put some of Grandmaws salve on it. LOL
Old 12-22-2015, 03:23 PM   #5
bk53
Fresh out of goose grease or duck butter Lawson. wbedwards, since its a new tank, I might hit it with a heat gun, no chance of blowing it up. v12bill, this is the same hose as came off the durn thing. Only thing new is the tank and thats the only thing that the hose goes on. I'm kind of week after a ten month battle with the big c. (they tell me I was on the winning team). I can give it about 15 minutes a try. This has got to be one of the worst jobs on this truck for scraping up a fellows hands and wrists.
Thanks fellas
Old 12-22-2015, 03:34 PM   #6
bk53
Thanks, the heat gun did the trick. forgot I even had the thing. Thanks for the idea.
Bill Merry Christmas, Happy New year and all that.
Old 12-22-2015, 08:55 PM   #7
wbedwards
wbedwards's Avatar
You would be shocked at all the things you can do with a heat gun once you spring for one.
