Old 03-02-2021, 07:07 PM   #41
o2bnkc
o2bnkc's Avatar
Default Re: My first dumb question
Originally Posted by Kens 36 View Post
Welcome to the Fordbarn! To complement your new '40, you absolutely need the new 40 Book from the Early Ford V-8 Club, available at https://shop.efv8.org/collections/fo...ng-rates-apply.
Ken
I think I do need to order it. It looks like it will come in handy.
A Proud Navy Veteran
o2bnkc is offline   Reply With Quote
Old 03-02-2021, 07:07 PM   #42
mfirth
By the way, there is no such thing as a stupid question.....so, welcome to "The Barn".
mike
mfirth is offline   Reply With Quote
Old 03-03-2021, 09:25 AM   #43
JayChicago
JayChicago's Avatar
Your carb may appear to be a single barrel because it has a single opening air horn. But look down the throat and you will see two venturies and two barrels below.
Old 03-03-2021, 09:45 AM   #44
19Fordy
19Fordy's Avatar
o2bnkc;
An oil filter on the stock 40 was a $7.50 option. Part 01A 18658-A.
Old 03-03-2021, 12:47 PM   #45
Terry,OH
Terry,OH's Avatar
There are two manufactures of the 94 style carburetor for the 1940 Ford. Both Holley and Ford made them. The Holley has a small "H" embossed and the Ford a letter "F" embossed, on the main body over the accelerator pump section. Both are marked 91-99 on the center main body. The top section is unique because it does not have a fuel bowl vent tube in the center of the venturi the bowl vents through a oval hole in the die casting. The internal parts are the same on both Carbs. so one rebuilding kit will repair either Carb. If you want an original Carb. Look to a rebuilder such as Charlie Schwindler in NY. Daytona in Florida sells a good rebuilding kit for the DIY.
Old 03-03-2021, 01:00 PM   #46
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 19Fordy View Post
o2bnkc;
WOW....That's ALMOST hard to fathom when you consider that $7.50 is well over ONE % of the MSRP of a WHOLE '40 Ford being approximately $660. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-03-2021, 01:26 PM   #47
solidaxle
solidaxle's Avatar
Welcome, I too was always a Vette guy. Now the Vette sits and I take out the Ford.
solidaxle is offline   Reply With Quote
Old 03-03-2021, 01:32 PM   #48
V8COOPMAN
V8COOPMAN's Avatar
Ahh! Now the term "solidaxle" makes sense....from one "Vette guy" (and owner) to another. DD
T5 W/TORQUE TUBE
Old 03-03-2021, 06:04 PM   #49
o2bnkc
o2bnkc's Avatar
That's exactly what I thought when I first looked at it. I've got a lot to learn here.
Old 03-03-2021, 06:06 PM   #50
o2bnkc
o2bnkc's Avatar
Great info. Thanks!!
Old 03-03-2021, 06:09 PM   #51
o2bnkc
o2bnkc's Avatar
You can't beat that! How do you enter pics on here?
Old 03-03-2021, 07:26 PM   #52
JSeery
JSeery's Avatar
There have been a number of past threads on uploading photos. The basics are, click Go Advanced, then on the bar across the top is a paper clip that opens a drop-down menu. That will open a pop-up window that allows you to select a photo and up-load it. There are a lot of pitfalls figuring it out the first few times, a big one is the file size limits.
Old 03-03-2021, 07:33 PM   #53
o2bnkc
o2bnkc's Avatar
Thanks for the help.
Old 03-03-2021, 07:52 PM   #54
JSeery
JSeery's Avatar
If you want anything posted while you are figuring it out, I can post them for you. Email them to me at [email protected]
Couple of links:
https://www.fordbarn.com/forum/showt...=posting+photo
Old 03-04-2021, 06:52 AM   #55
moefuzz
moefuzz's Avatar
's
Originally Posted by o2bnkc View Post
So the carb in my 40 is a Holley94?
Not necessarily,
Did you say the engine was an 8BA? -in your 40?
Carbs....
It could have been swapped out many times.
It could say Ford on the carb
It could say Holley on the side
It could say Chandler Groves on the side
All these carbs appear near identical to the unknowing eye.
Things get swapped around and hacked in and sometimes the wrong carb is in where a Load-O-Matic (a later version of the "94") should be.
I would expect that having the original or correct carb on the car is about as likely as having the original Ford Factory Air in all the tires...
....But if you have an 8BA engine (1949 -54 Flathead) in your 40 than more than likely It's probably got it's 'correct' Holley 94 Load-O-Matic and they are reliable and easy to work on...
cheers, moe of the north
moefuzz is offline   Reply With Quote
Old 03-04-2021, 10:51 AM   #56
solidaxle
solidaxle's Avatar
I have owned that 61 for 35 years and can't give it up. NCRS member 10654 and have had the car reach Top flight. I don't even look at Vetts anymore at car shows, well maybe a glance.
Old 03-04-2021, 03:57 PM   #57
AnthonyG
AnthonyG's Avatar
I’ve had 3 Vettes, if I saw the right deal in a ‘71 or earlier would do it again in a minute! This was the prettiest! Thought I made out great when I sold in 1983 for $15,000, should never have sold it! shoulda woulda coulda
File Type: jpg 33029925-5BB3-4C23-8252-B7637E9F5CE3.jpg (51.3 KB, 13 views)
Nomad
AnthonyG is offline   Reply With Quote
Old 03-04-2021, 04:26 PM   #58
Lanny
Lanny's Avatar
Anthony, your Vette looks like it was in pretty nice condition for a '61 or '62
as it would have been over 20 years old when you sold it then.
Also, unless '71 has a sentimental value, don't pass up a '72, as they are
almost identical to a '71. and in the same ball park, value wise.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 03-04-2021, 04:33 PM   #59
AnthonyG
AnthonyG's Avatar
Agreed Lanny!
Nomad
Old 03-04-2021, 06:09 PM   #60
TonyM
TonyM's Avatar
Hey everybody. New guy here. I've always been a corvette guy, but there's nothing more beautiful to me than a 32-40 Ford with a flathead. I finally got my 1940 Deluxe last Thursday. I'm jazzed!! I'm sure this is only the first of my stupid questions over the next few years, but what is an "8ba"?
Welcome. Some sharp Ford people on this forum.
TonyM is offline   Reply With Quote
