Old 11-20-2017, 06:30 PM   #1
G_Don
Default Headlight Switch Sticking
Hi All,
I just put a new headlight wiring harness in. No problems with the install except it does not seem to operate smoothly. The switch is difficult to turn, almost to the point where it feels like I have to force it.
Wondering if I am supposed to apply any type of grease or dielectric grease to it to get it to operate more smoothly?
Thanks in advance for your time!
Gordon
G_Don is offline   Reply With Quote
Old 11-20-2017, 06:54 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Headlight Switch Sticking
The dielectric grease won't hurt a thing.
Paul in CT
Old 11-20-2017, 07:07 PM   #3
JDupuis
JDupuis's Avatar
Hi Gordon, the bakelite portion of the new harness is probably a "thicker" diameter than the original. I've had to file down the outside lip in the past so the harness doesn't press so hard on the switch portion.
The thickness difference could the thickness of a dime to the thickness of a quarter. Hope this helps.
Don't file the outside diameter.
If I recall I filed the back side. Where the wires attach. Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 11-20-2017, 07:15 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I think Jeff is right, as the repro I installed for a customer about 10 years ago was very stiff to turn.
I sanded each divot to round over the edge, and that helped. I also applied grease to the divots.
Old 11-20-2017, 07:44 PM   #5
slammin
slammin's Avatar
I had the same problem with mine. I bought the US made wiring harness from Berts and the US made light switch from Brattons. Steve at Berts put one together and found a solution. He carefully belt sanded about 3/32 from the lower part of the switch. I put the harness in the bottom, assembled the top (out of the car). Inserted the spider and tried to move it with a 1/4" drive ratchet. I kept sanding more off until it worked smoothly. It took a while, but after 2 weeks of fighting it, including shearing the ears of the spider, I HAVE LIGHTS!
slammin is offline   Reply With Quote
Old 11-20-2017, 09:07 PM   #6
SteveB31
SteveB31's Avatar
Much easier to sand just a bit off the lower metal piece lip, then sanding the black disk or each divot.
SteveB31 is offline   Reply With Quote
Old 11-21-2017, 03:36 PM   #7
Tinbasher
Tinbasher's Avatar
All the tricks!!
Tinbasher is offline   Reply With Quote
Old 11-22-2017, 05:18 AM   #8
Bruce of MN
Bruce of MN's Avatar
In an earlier thread, a poster suggested making sure the light switch rod bushing was there https://www.brattons.com/light-switch-rod-bushing.html
When I rebuilt my steering box last year, I didn't check for that, but will. My switch sticks and turns on the headlights when I turn, so I'll look at that thickness to see how it compares to my old one.
Bruce of MN is online now   Reply With Quote
Old 11-22-2017, 08:55 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
A new headlight switch will be difficult to operate until it accumulates some wear on the contacts. NOS original light switches exhibit harsh operation as well until they wear some. Use the dielectric grease.
Bob Bidonde
Old 11-22-2017, 02:28 PM   #10
slammin
slammin's Avatar
As part of my solution I carefully milled the plastic contact holder thickness from the oversize .335 to the spec .310 and filed all the contacts flush to the plastic surface. If you view the photo closely you can see the difference in the size of the contacts after filing.
Old 11-22-2017, 05:33 PM   #11
G_Don
I ended up using the dielectric grease and it feels a great deal better. Still a little tight but I'm hoping itll just break in over time. I was nervous to shorten the contact housing however over time, if it doesnt break in, I'll be sure to try something different!
Thanks for all the replies! I really appreciate it!
Gordon
