Old 09-22-2016, 07:42 AM   #1
Mitch//pa
Default Toss your old school ray gun
I got this thermal imager and what a difference to be able to detect cold / hot spots over the traditional way.... Running this across the radiator and being able to see the variances visually is night and day over what we're use to when using the old school ray guns.....
You can easily check your home from heat or cold loss, find wall studs etc...
I pulled a wire on the A spark plug and was easily able to detect the non firing cylinder by scanning the exhaust manifold... The traditional Ray gun was not able to as the temp differences were to close but with the thermal imaging it nicely showed up. It can be pointed at any electrically operated device such as a fuel injector to see if it's working... Unlimited uses....
Just passing the info along to the gang. This has 4,800 pixels which is much better than the cheaper ones on the market...
FLIR TG165 Spot Thermal Camera with Image Storage https://www.amazon.com/dp/B00NXJDQV0..._l784xbF8NZSWP
Old 09-22-2016, 08:13 AM   #2
Rex_A_Lott
Default Re: Toss your old ray gun
We've used thermal imaging cameras at work for years, but they cost SEVERAL thousand dollars. They are good for diagnosing electrical problems that involve bad connections ( high resistance=heat).Also good for checking dead spots in a coil (radiator).
Nice to see they are becoming more afFORDable. Thanks for the heads up Mitch
Rex_A_Lott is offline   Reply With Quote
Old 09-22-2016, 09:28 AM   #3
C26Pinelake
Great for the professional mechanic or a shop, but Not at all practical for the hobbyist that might use it once every five years. Harbor Freight is still the tool of the hobbyist. Wayne.
C26Pinelake is offline   Reply With Quote
Old 09-22-2016, 11:21 AM   #4
mhsprecher
mhsprecher's Avatar
Thanks, Mitch. More affordable, but still pretty expensive for the average buyer for occasional use.
mhsprecher is offline   Reply With Quote
Old 09-22-2016, 12:03 PM   #5
1931 flamingo
1931 flamingo's Avatar
Mitch: Most (all) of us don't have the money tree in our backyard that you do.
Paul
Old 09-22-2016, 12:24 PM   #6
Mitch//pa
Paul::: I guess treating you to that hot dog gave the wrong impression
Old 09-22-2016, 12:48 PM   #7
Ted Duke
If enough of you guys buy it the price will come down. When it gets to $34.80 I'll snap one up just for kicks!
Ted
Ted Duke is offline   Reply With Quote
Old 09-22-2016, 05:45 PM   #8
Mitch//pa
Default Re: Toss your old school ray gun
I changed the title to "Toss your old school ray gun "
