Old 01-06-2021, 09:27 AM   #21
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Sound deadening Q ?
Hi Terry,
I think Ford read your mind, and that's why the doors have gobs of that tar-like stuff.
Bob Bidonde
Old 01-06-2021, 09:45 AM   #22
Dick Carne
Dick Carne's Avatar
You asked about sound deadening for roadster/touring car doors. When we first did our phaeton back in the 1960's, we stuffed the doors with fiberglass separated from the traditional house insulation roll. It seemed to substantially deaden the sound, and also added more of a "classic door closing sound" as well. Since these doors would otherwise be difficult to add a more conventional sound deadening material (like Dynamat, for instance), this seemed to be an otherwise inexpensive means of deadening the door sound. Perhaps the only real caveat that I can see is the possibility of trapped moisture inside the door, but we seldom drive our open cars in the rain (if we can help it), and are generally careful not to let water run down the side curtain rod opening in any event. After more than fifty years, no problems to this point.
Dick Carne is offline   Reply With Quote
Old 01-07-2021, 07:35 AM   #23
DkFordor
Originally Posted by Bob Bidonde View Post
The science of sound deadening body panels is to change their mass.
Bob, that holds for vibrations of the car itself for sure. Does it hold for transmitted noises from the outside also?
\Dan
DkFordor is offline   Reply With Quote
Old 01-07-2021, 03:21 PM   #24
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by PotvinV8 View Post
Bob Bidonde's photos are a perfect example of how to apply any decent "deadener". You don't need to coat the entire door skin, roof, etc., small strips will suffice. Knock on the sheetmetal with your knuckles and you'll hear the difference. A little goes a long way.
While Bob's method may work well for the tinny body panels, it does nothing for engine and road noise and for heat.
I covered my entire floor in my Town Sedan with DynaMat, followed by Jute backed foil and finally carpet. Nice and quiet. I also insulated the fire wall.
I eventually went back and fully insulated the insides of the doors and body to make it even quieter inside.
Old 01-07-2021, 05:48 PM   #25
old31
I agree 100% with Y.
Bob's method would change the sound/vibration of an item, but does nothing to truly soundproof or heat/air proof the car. On top of what Bob did I would apply Dynamat to all surfaces while the upholstery is out.
Old 01-08-2021, 08:46 AM   #26
DkFordor
What have you guys done (if anything at all ) to insulate the roof, soundwise and thermally?
Could a material like dynaliner, or something similar, be used above the metal net instead of the cotton wadding/padding?
\Dan
Old 01-12-2021, 02:41 PM   #27
hardtimes
hardtimes's Avatar
Originally Posted by CarlG View Post
I have used Dynamat, but more recently I have been using RoadKill. I have to order Dynamat and pay freight to get it here. RoadKill I can get locally. It is actually a little easier to work with and does a good job.
Hey Carl,
ROADKILL....eh ?
That's got to be one smelly car !!
And here I thot that A skunk, stuck up in the chassis was bad..whew !!
Never thot of insulating withem...lol
Lot of roadkill moose up that way....wonder how many cars/trucks one of those would do ?
hardtimes is offline   Reply With Quote
Old 01-12-2021, 02:57 PM   #28
GeneBob
DkFordor,
I sound deadened the sheet metal on my Tudor and have found that the roof really isn't a problem. I think the stock construction may work very well for insulation.
GeneBob is offline   Reply With Quote
Old 01-12-2021, 03:33 PM   #29
PotvinV8
PotvinV8's Avatar
I'll give you that, but now we're splitting hairs as to the OP's original post!
I've found the Dynaliner product line works very well as a second layer of insulation on the floor, firewall and roof to block out additional heat and noise. It's available in a few different thicknesses as well.
PotvinV8 is offline   Reply With Quote
Old 01-13-2021, 12:54 PM   #30
CarlG
CarlG's Avatar
Originally Posted by hardtimes View Post
Hey Carl,
ROADKILL....eh ?
This is the "RoadKill" I use:
File Type: jpg roadkill-ultimate-universal-kit-788567_1728x.jpg (36.8 KB, 19 views)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
