Old 12-09-2017, 06:18 PM   #1
mike657894
mike657894's Avatar
Default is the throw out bearing supposed to have play?
im cleaning the engine bay to weld the cross member and paint what i can get too while the engine is out. And i look at the throw out bearing and give it a shake there is enough play to make it click is this ok?
mike657894 is offline   Reply With Quote
Old 12-09-2017, 06:56 PM   #2
figment
Default Re: is the throw out bearing supposed to have play?
If it makes any kind of noise I would recommend changing it and the small bering in the flywheel . Now is the best time to do this job .
figment is offline   Reply With Quote
Old 12-09-2017, 08:06 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Even if you replace the bearings, re-pack them with a Wheel Bearing Packer. The grease they pack them with is almost like VASELINE!
Bill Practical
"THE ASSISTANT GURU OF STUFF"
Old 12-09-2017, 08:19 PM   #4
2manycars
2manycars's Avatar
I never use a bearing in the flywheel. The original were open bearings and got gunked up with clutch material and seized, ruining the input shaft. The new replacements are sealed, and the seals are so tight that the shaft spins in the bearing and the bearing does not spin. I use a bronze bushing, like Ford did in later years. If a bushing is good enough for a 427 with 4 speed, it is plenty good enough for a model A. the correct bushing can be gotten at NAPA and other auto retailers.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 12-09-2017, 10:15 PM   #5
1930-Pickup
That's sound advice.
Many folks are concerned about lubricant in the plain bearings (bushings), but the right ones are oil impregnated, so lubrication is not a problem.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 12-10-2017, 09:31 AM   #6
V4F
V4F's Avatar
change it now -- or change it later . with motor out it really is no question .
V4f
V4F is offline   Reply With Quote
Old 12-10-2017, 12:33 PM   #7
100IH
Off track fellas. T/O bearing and not Pilot bearing. I like the older bearings that have a hole at the inner diameter for the grease to enter the bearing and not just lube the bearing retainer sleeve. The new stuff I've seen have been sealed and would be difficult to even hand pack.
100IH is offline   Reply With Quote
Old 12-10-2017, 12:54 PM   #8
mike657894
mike657894's Avatar
I looked around And macs had a bronze bushing listed for early v8s 32 trucks and on for 9$. Would that one be a fit? Napa has abandoned my area. There is a auto value affiliated owner operated parts shop ill go to with my mics and the bearing.
On the throw out bearing I'll have to get a new one.
https://www.macsautoparts.com/store/...Product_Viewed
Old 12-10-2017, 03:16 PM   #9
2manycars
2manycars's Avatar
Not off track. post #2 mentions changing the pilot bearing. That is why I responded.
Bill
www.brauchauto.com
