Old 09-13-2017, 07:37 AM   #21
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Ford tractor engine ?'s
Originally Posted by midgetracer View Post
The 40 ford pickup 4 banger is a direct swap. Only real change is the fuel pump must be blocked off. Not a popular engine in the pickup though.
Had a '40 Pickup I restored from an engine fire, GREAT, SMOOTH truck, with a 4:44 rear end & doesn't go very FAST. Drag Racers would pay BIG bucks for those gears. The '37 V-8 60s had the SAME gears!
Bill Slow
"THE ASSISTANT GURU OF STUFF"
Old 09-13-2017, 11:44 AM   #22
40 Deluxe
Originally Posted by Keith True View Post
Actually the story I've heard repeated most of all is that the Fordsons used the T engine.I've owned a couple of Fordsons too.I had one on dual wheel.hard rubber tires,and that one was strictly gas,not meant to run on kerosene at all.It was for pulling planes around in a hanger and they didn't want the smoke from the kero sooting the place up.I had one on tracks too.Full tracks,not over the tire add-ons.That was called a Traxon.It was mean and could hurt you.
Just to clarify your post: The Fordson engine was NOT the T engine (in case anyone might think that story is true). Totally different. The only thing the same was the flywheel magneto ignition system.
