01-30-2017, 05:20 PM | #1 |
Light Switch Spider removal
Is the removal tool the only way to do it? I was at Brattons today and could have bought one, but didn't think of it.
01-30-2017, 05:27 PM | #2 |
Re: Light Switch Spider removal
It helps, but if you have tough fingers you can depress the spider enough to get the key out.
01-30-2017, 05:33 PM | #3 |
Yes strong fingers, or a homemade tool like this. Jeff
Let's let pylons, be pylons! |
01-30-2017, 06:02 PM | #4 |
I must have callused fingers or a weak spring but I didn't think it was too bad to do it with my bare hands. I think the trick was be rough and do it once or twice. After 5 min of pushing on that thing it does start to hurt.
01-30-2017, 06:45 PM | #5 |
I use the removal tool to depress the spring, then grab the clip with a pair of hemostats. Very easy.
01-30-2017, 07:03 PM | #6 |
01-30-2017, 07:12 PM | #7 |
When I lever the spider up, the rod goes with it and the clip is still trapped.
My sector housing broke where the eccentric is, so a new one will go in. |
01-30-2017, 07:17 PM | #8 |
As Tom once mentioned, put a board across under the steering wheel and over the light switch lever to hold the rod from pushing up..
01-30-2017, 07:44 PM | #9 |
as Tom has said put a yard stick through the steering wheel to hold the horn rod in. I have tied all kind of different tools on the spider. the vise gripes work the best for me.
01-30-2017, 07:48 PM | #10 |
Thats right a yard stick.....lol
01-30-2017, 08:27 PM | #11 |
John shared using the needle nose vice grip with me several years ago and it is the only way to go!!!
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
01-30-2017, 09:41 PM | #12 |
Thanks to all! I use my needle nose vise grips a lot, don't know why I didn't think of it for this?
Thread Tools | |
Display Modes | |
