02-24-2015, 10:07 PM | #1 |
Generator end plate bushing size.
Just tore down my generator because it started making noise. Found the rear end plate bushing was bad. I miked the armature shaft end and found it is .662 to .669 depending on location. The OD of the end plate bushing hole is tapered from .808 to .813. Neither of these measurements corresponds with any Ford generator bushing I can find. Not wanting to make it a unique size I'm tempted to turn the shaft end to .625 and bore and bush the end plate to .750 to take use a standard 32 to 36 bushing as shown in the Macs catalog.
Anyone have a better plan/idea? |
02-24-2015, 10:13 PM | #2 |
Re: Generator end plate bushing size.
The last time I needed a cintered bronze bushing, found one of suitable size with a little modification in the bins at local hardware store.
02-25-2015, 04:40 AM | #3 |
Doing it the way you propose is the right way to do it; the journal and bore in end plate will all be round. I always prime the oillite bush too by squeezing oil through it with thumb and forefinger, prior to installation.
02-25-2015, 07:16 PM | #4 |
