03-08-2021, 10:02 AM | #21 |
Re: Installing 95% oil filter system issue
I think the clearance issue is going to depend on a lot of factors that can very between installations. You just about going to have to figure it out as you go. Might consider a trial fitting with a separate piece of tubing before you start binding the one you intend to use.
03-08-2021, 12:22 PM | #22 |
If you are worried about clearance with your headers, then you can put an 1/8" NPT 90 degree male-to-female elbow into the block, then the adapter from 1/8" NPT to 1/4" compression/flare. This should enable you to keep the line close to the block and away from the headers. Now, you may have to make or modify your own lines - but that isn't a big deal.
Best of luck on getting your new engine done and on the road! B&S |
03-10-2021, 12:16 PM | #23 |
Couldn’t find the right adapter at hardware store. Found the 1/4”-1/8” pipe thread adapter but couldn’t find the one with the nipple on the inside that the tube flare needs. What’s it called? Thinking the ones I found that were similar but w/o a nipple were NPT.
Nomad |
03-10-2021, 01:19 PM | #24 |
its a flare fitting. auto store should have it, common on vacuum lines, brake lines etc
03-10-2021, 01:24 PM | #25 |
03-11-2021, 07:36 AM | #26 |
03-11-2021, 08:15 AM | #27 | |
When it comes to flare fittings - you need to know which flare type - there are three. It is most likely that you're looking for a 45 degree angle SAE type flare. Don't make the mistake of buying an aircraft flare 'AN' of 37 degrees. |
03-11-2021, 09:17 AM | #28 |
I discovered the correct fittings were on the filter I got. There’s 2, the one at the top is a 90 degree, the one at the bottom is strait. Just to get the motor in I took the 1 off the bottom & used on the return treaded hole on the block. Good for now. I think the correct designation for the fitting is npsm 1/8” male-npt 1/4” female, adapter.
Nomad Last edited by AnthonyG; 03-11-2021 at 09:30 AM. |
03-11-2021, 11:10 AM | #29 |
Actually (1/8 male NPT- 1/4 Female inverted flare )
03-11-2021, 01:30 PM | #30 |
Here are the instructions I used on my flatheads. Now I still have oil pressure at an idle.
03-11-2021, 02:03 PM | #31 |
Got it & thx again! 51 Merc-Ct SleezeBay had
Nomad |
03-11-2021, 02:20 PM | #32 |
These are the instructions I used on my engine. Now there is oil pressure at an idle.
03-11-2021, 02:41 PM | #33 |
Thats a good one Ken ,
