12-07-2020, 06:42 AM | #41 |
Re: 4 post lifts
I have a 4 post but it now seems to leak down when it is raised up it not on stops.bought it at a Goodguys some 10 yrs ago here at Atl motor speedway.It was a demo they had and he didn't want to take it down and move it but he did deliver it to my house.Back to the leaking down what will cause it the cylindr do not have a leak
12-07-2020, 07:16 AM | #42 | |
Re: 4 post lifts
12-07-2020, 09:22 AM | #43 | |
Re: 4 post lifts
12-08-2020, 06:17 AM | #44 |
Re: 4 post lifts
Thanks it is a Danmar lift.Some one bought them out now so I can't call them.It will creep down in between stops.You can hear it.
12-08-2020, 08:49 AM | #45 |
Re: 4 post lifts
Sounds like you’ll need a lift repair guy to check it out..... Mark
12-09-2020, 06:14 AM | #46 |
Re: 4 post lifts
12-09-2020, 08:58 AM | #47 |
Re: 4 post lifts
I have a 2 post Atlas for about 7 years and love it. It is priced right, you don't have to purchase an expensive rolling rack, and it uses less floor space than a 4 post.
Why go with a 4 post when a 2 will do everything, storage, front ends. Bendpaks and all the others that are mentioned are good products, but do you really have to spend that kind of money? |
12-09-2020, 10:39 AM | #48 | |
Re: 4 post lifts
12-09-2020, 11:20 AM | #49 |
Re: 4 post lifts
Denny as usual your right on.
In addition, a 2 post needs a wider area. My 3 car garage had width limitation due to poles which support my beams and 14’ height. Due to this fact 2 post was not an option. Very happy with the four post.
Thanks Andy 1952 F1 |
12-09-2020, 08:28 PM | #50 |
Re: 4 post lifts
Was wondering if anyone has a Gemini MODEL GM 7000 4 Post Lift? If so any comments on its quality. Stay Safe!
Bob |
12-12-2020, 06:19 AM | #51 |
Re: 4 post lifts
Left My lift up while working on my Model A and the next day the cables were sagging after I hade lowered it on the stops trying to change the 4 bar bushing.Hit the up button and hey tighten up and next day sag again.So I have a leak somewhere not visible from cylinder
12-28-2020, 09:56 PM | #52 |
Re: 4 post lifts
So I’m going to add another question to this and it’s around the power source. I ordered the caster kit that allows me to move the lift around so it made sense to get the 120v so if I moved it to could be easily plugged in VS the 220 being hard wired and less movable.
I’ve read the only difference is the lift time bing about 1 minute 40 seconds VS half that on 220. Is one much better then the other? |
12-28-2020, 10:47 PM | #53 |
Re: 4 post lifts
Anyone have this 4 Post Lift? Thanks,
Bob |
12-28-2020, 10:49 PM | #54 |
Re: 4 post lifts
I ordered the 120 V pump because there was an outlet right at the left front corner of the lift. I have nothing to compare it to but lift time has not been a problem. I was not concerned as I bolted mine to the floor.
12-29-2020, 06:19 AM | #55 |
Re: 4 post lifts
Had to take cylinder out and have the seals replaced hope to get it back today.It was leaking down bad and getting worse.It is about11 years old but I guess it happens from time to time.
02-05-2021, 11:19 AM | #56 |
Re: 4 post lifts
I got the lift installed and in service.
02-05-2021, 11:44 AM | #57 |
Re: 4 post lifts
Looks nice!
