Old 05-18-2019, 02:27 PM   #1
Bill Lee/Virginia
Default 1931 4 Door Flat Firewall vs Indented Firewall
Is there any difference between the construction (wood/steel) of the 1931 4 Door Flat Firewall and the Indented Firewall?
Bill Lee/Virginia Peninsula
Bill Lee/Virginia is offline   Reply With Quote
Old 05-18-2019, 02:36 PM   #2
Charlie Stephens
Default Re: 1931 4 Door Flat Firewall vs Indented Firewall
No significant difference as long as they are both slant windows. The vertical window sedan of early 1931 had the same amount of wood as the earlier bodies.
Charlie Stephens
Old 05-18-2019, 02:41 PM   #3
Bill Lee/Virginia
Sir:
Thank you for the prompt reply.
My car is the slant window model.
Old 05-19-2019, 08:33 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Slant window Fordors made by Briggs and Murray have interchangeable body parts. That's what H. Ford demanded of them! The fit of the firewalls fit into the cowls are the same for both 1931 straight & slant window cars.
Bob Bidonde
Old 05-19-2019, 09:55 AM   #5
duke36
Many of the early sw's had the support for the steering column attached at the gas tank with the straight firewall, then later moved to the dash rail (see the Service Bulletins, etc.)
duke36 is offline   Reply With Quote
