01-03-2019, 03:35 PM | #1 |
Working on the '41
I spent the holidays working on my 'new to me' '41 Business coupe.
New: Tail lights, Bob Drake water pumps, King pins, MT Bendix brakes, Master cylinder, Trunk lock cylinder, Vent windows and Trunk rubber seal. Replace: broken horn ring, leaking shocks, adjust steering box fill & with cornhead grease and remove years of crud from steering components. Halfway through doing the brakes I found that the right rear hub wouldn't come off. After a lot of swearing it finally came loose and then I found the reason (see below), now the search is on for a replacement axle shaft . Any suggestions for a source would be appreciated , I don't need NOS, just a good used one will do.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
01-03-2019, 03:40 PM | #2 |
Re: Working on the '41
And it did'nt break !! The wonders of ford steel. That is amazing.
01-03-2019, 03:45 PM | #3 |
And the HUB???
01-03-2019, 03:49 PM | #4 |
That is amazing that it didn't break. You are a lucky man. |
01-03-2019, 04:28 PM | #5 |
Is that the same as a 41 sedan ?
01-03-2019, 04:41 PM | #6 |
01-03-2019, 05:25 PM | #7 | |
Amazing! Looks like it did fracture - close to coming apart! Must have gotten hot or been heated! Lots of work --you're the man. Have a couple here in Tulsa Oklahoma ----and they come installed in a 1942 Ford SEDAN DELVERY! What say? Really. Gene Old Route 66 Oklahoma |
01-03-2019, 05:36 PM | #8 |
I think I saw on here a few days ago that Fred Wilner at Southside Obsolete has NOS axle shafts. If I had to go through all the effort that is required to replace an axle shaft in one of these cars, I would want the best replacement possible. It is a job you DO NOT want to do twice because you cheaped out on parts. He is "barnfind08" on here.
If I had to do it (again), I would replace both axles with NOS parts if available. That axle is a definite "wall-hanger" though! Last edited by tubman; 01-03-2019 at 07:15 PM. |
01-03-2019, 05:53 PM | #9 |
Check with Russell Haines in Ashburton, he may have one or know where to get one & a hub.
Good Luck! Cheers Tony |
01-03-2019, 05:56 PM | #10 |
Yes, I already have spare hubs so that is not so much of a problem.Thanks, Meric.
01-03-2019, 06:00 PM | #11 |
Yes I believe so, 32.85", 16 teeth the same axle from '39 to '41 with the part #: 81A-4235.
01-03-2019, 06:11 PM | #12 | |
Thanks Gene, the '42 (33.7") axles are about an inch longer than the '39 - '41 (32.85"). I already have 2 '42 Sedan Delivery's, one of which came from Claremore OK in 1995, so I can't justify buying another . This '41 and the other 3 cars ('51, '53 & '57 Ford Convertibles) I bought last year also came from the same collection in Claremore. They belonged to a very good friend of mine who passed away in October of 2017 and I purchased these from the family last year.
01-03-2019, 06:38 PM | #13 |
Did you go buy a Lotto ticket?
01-03-2019, 06:43 PM | #14 |
01-03-2019, 06:57 PM | #15 |
JB it , ! Just kidding of course . I'll check in the next couple days . Could the flu while flying to Texas . Sneeze , sneeze , cough . Yes the cough meds make you a little goofy .
01-03-2019, 09:37 PM | #16 |
Post a want ad in the sales section. I wound up getting a pair of near NOS axles for my 41 from Barnfind08 (thanks mate) here.
Shipping will make your eyes water but that's life in the Antipodes for you! |
01-03-2019, 11:03 PM | #17 |
Meric, Bruce Ardell in Fordell has one 81A axle. Last year when I built my Columbia, I purchased off of Bruce, two NORS 81A axles. He had three to choose from. The one I discounted was not in fact new; had been used, but is still a very good replacement axle, mint taper and keyway, first couple of threads looked a bit ropey. Phone Bruce 06 342 7713
01-04-2019, 12:56 AM | #18 |
Or...Stateside, Bob Selzam [Half Ton Fun], has one only NOS genuine Ford axle, but it is rusty.
01-04-2019, 08:50 AM | #19 |
No way I add salt to injury, but I see this all the time, that did not happen overnite. We
had a 2010 F350 come in with a melted rear end, ring & pinion fused outer wheel bearings fused to axle housings, total junk. Not being wise but somebody needs a hearing aid or new batterys for it. That truck must have screamed for a long time. Yours could be built up, turn new taper, keyway, re thread, but someone has one and a new hub.... bet Ray Helger Little Compton RI has a NOS axle. He stocks thing that ain't been invented yet LOL Rays phone 401-635-4849 sam |
01-05-2019, 12:21 PM | #20 |
I have a used one. The taper and key looks really good but the side gear has rust pits.
PM an email or cell and I'll send pics. |
