Old 11-05-2018, 11:45 AM   #1
1930deluxe
Default Modify 1930 tudor sedan
I am debating whether to eliminate the second tire from the front fenders on my 1930 tudor sedan. The fenders have a tire on each side. The fender wells are rusted through in several spots and it is $42.00 ea. plus shipping for a new fender wells. I could weld a plate in one and eliminate one.
1930deluxe is offline   Reply With Quote
Old 11-05-2018, 11:58 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Modify 1930 tudor sedan
Unless you are doing the patch the cost would be VERY costly. Plus they/you will have to get the right slope and curve. It might be easier to just get a regular fender.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 11-05-2018, 12:12 PM   #3
40 Deluxe
So for a hundred dollars or less you have new fender wells, with a lot less metal work. Paint cost will be about the same either way. To weld in a plate without ending up with ripples and waves will be a lot of work (or expense)!
Old 11-05-2018, 05:03 PM   #4
1930deluxe
I would be welding the metal in my self and doing the the body work, and paint A New fender are over $650.00 and will need work to make it fit.
Old 11-05-2018, 05:07 PM   #5
1930deluxe
By eliminating one spare tire I would also eliminate a rim, tire, mounting hardware and would be able to open the door all the way without hitting the tire.
Old 11-05-2018, 05:13 PM   #6
40 Deluxe
Seems you have the overall big picture. I didn't!
Old 11-05-2018, 07:42 PM   #7
Gene F
Gene F's Avatar
I must say, I like my spare on the back. Never had a side-mount car, but they don't turn me off either. I guess it's a matter of preference.
Gene F is offline   Reply With Quote
Old 11-06-2018, 10:49 AM   #8
Jim Brierley
If you are not going to show the car, fiberglass the inside of the well and re-finish the outer area. One spare is enough but that is up to you.
Jim Brierley is offline   Reply With Quote
Old 11-06-2018, 11:12 AM   #9
Hoovercw
I bet you would find someone eager to trade a regular fender for yours. Finding someone local is a different story.
Hoovercw is offline   Reply With Quote
Old 11-06-2018, 11:31 AM   #10
rocket1
I would remove the driver side fender well spare,It is really a chore to get out of my 29ccpu with the tire restricting the door opening,not a great idea Henry!
rocket1 is offline   Reply With Quote
