Old 08-20-2018, 06:02 PM   #1
daren007
Default Tough question.
Inside the armored wire housing on the "A" distributor there is a smaller spring type housing but now the question. Why is there a itty bitty wire running parallel to the electrical wire inside this housing.
daren007 is offline   Reply With Quote
Old 08-20-2018, 09:11 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Tough question.
It acts as a ground and most importantly stops someone from stretching the coiled outer spring, which might pull the copper wire out of the brass terminal on the end.
Old 08-21-2018, 07:31 AM   #3
daren007
I was thinking the same thing about a stretch limiter but as a ground? Thanks.
Daren
Old 08-21-2018, 12:57 PM   #4
100IH
Called strain relief
100IH is offline   Reply With Quote
