Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 06-22-2014, 02:27 PM   #1
alrogers
Default 1933 Parts Wanted Can you help me out?
City: Northborough
State: Ma
I am also looking for the follow item NOS only….
  • 18-4211 NOS Rear end spider cross shaft (that the spider gear ride on)
  • 18-4215 NOS Spider Gears Fits 1932-38 have 12 Teeth
  • 18-4235 NOS 1933 34 Axle 18 teeth 32.18” long, fits only 33-34 please be aware a 1935 axle is 32.85” long and looks almost the same but is not!
  • 40-16067-2 NOS or used Front Fender small braces from frame at front cross member to fender brackets
  • 48-13480 NOS Stop light switch
  • B-3647-B The bale on the bottom of the steering box that holds the light switch onto the steering box
  • B-3642 NOS or good used The spider on the bottom of the horn rod
  • B-3686 NOS or good used Ignition Lock with key and nice original chrome or redone chrome
  • 01A-7100 NOS transmission reverse slider gear
The parts I need below can be good used parts
  • 1933 dip stick, I have a photo of the one I’m looking for if you need it
  • A decent used 1933 speedometer with 2 digits and the tenth wheel on the tripometer not 3 digits and the tenth wheel on the tripometer
  • Name of any one who can rebuild a 1933 Speedometer?
  • A decent “take off” 1933 bumper 21.78” between the bumper bolt holes
  • A good used drivers side inner front bumper support bar
  • A rebuilt or rebuilding kit for a 1933 fuel pump
  • 40-17270 Speedometer gear on the rear drive shaft with18 or 11/39 marked on it for a 354 ratio rear end.
  • A 17” metal outer spare tire metal cover with the SS on the center
  • A pair of accessory 1933-34 rear fender skirts?
  • A good used hydrostatic gas tank sender unit.
I have detailed photos of most of these parts I am looking for so if you “think you have what I need” I can send you a photo to be sure it’s what I am looking for.
Please email me [email protected]
Thanks
Al
alrogers is offline   Reply With Quote
