05-14-2014, 12:50 AM | #1 |
33 dash engine turning, does anyone make one? Or a thin engine turned material?
Where can I buy a 33 dash with engine turning that I can use the original guages in?
Or who makes a this metal turned material that can be attached to an original 33 dash insert? All leads appreciated! Al Rogers |
05-14-2014, 05:32 AM | #2 |
Re: 33 dash engine turning, does anyone make one? Or a thin engine turned material?
Here's an old HAMB thread on the subject (Google is your friend): http://www.jalopyjournal.com/forum/t...luminum.92762/
05-14-2014, 07:19 AM | #3 |
The material is aluminum and can be "engine turned" on a drill press. You need a guide that can be moved to keep the swiriles in line and you nest the next row like stacking oranges. Takes a little time but not difficult. G.M.
www.fordcollector.com |
05-14-2014, 10:29 AM | #4 |
tom |
