08-25-2013, 03:08 PM | #1 |
spark advance lever
New to the model a. To get my car running last week I had to disconnect my spark advance lever and retard the points by hand. When the lever is all the way up, the points are all the way advanced. Is there an adjustment or could the rod be to short? Off the car the rod is about 17" long.
08-25-2013, 03:14 PM | #2 |
Re: spark advance lever
Research:
"How To Time A Model A" |
08-25-2013, 03:36 PM | #3 |
08-25-2013, 03:44 PM | #4 |
17" sounds about right. You could try filing the opening in the dist body a bit.
New question" What year is your car?? Is it possible the steering column "cover" has been rotated and you're not getting full motion?? Paul in CT |
08-25-2013, 03:45 PM | #5 |
08-25-2013, 03:46 PM | #6 |
08-25-2013, 04:58 PM | #7 |
Thanks pat in santa cruz that's what I was looking for.
41plym |
08-25-2013, 05:43 PM | #8 |
I have to disagree with Paul about filing the body. I don't think that is a good idea. That opening controls the correct movement of the upper plate.
08-25-2013, 05:46 PM | #9 |
Thanks guys, Pat was spot on, its now fixed and working correctly without any modifications.
41plym |
