Old 09-16-2020, 07:40 PM   #1
47Monarch
47Monarch's Avatar
Default Flame thrower coil
Will a 40011 flame thrower coil work in my 47 Monarch
47Monarch is offline   Reply With Quote
Old 09-16-2020, 07:57 PM   #2
JSeery
JSeery's Avatar
Default Re: Flame thrower coil
What is the coil resistance and is it a stock distributor? It all depends on the current flow in the circuit.
Looks like it is a 1.5 ohm coil, so it should work with 6v or 12v with a ballast resistor.
Brand:PerTronix
Manufacturer's Part Number:40011
Part Type:Ignition Coils
Product Line:PerTronix Flame-Thrower Ignition Coils
Summit Racing Part Number:PNX-40011
UPC:694342004866
Coil Style:Remote mount
Primary Resistance:1.500 ohms
Coil Internal Construction:Oil-filled
Coil Wire Attachment:Female/Socket
Coil Color:Black
Maximum Voltage:40,000 V
Turns Ratio:115:1
Secondary Resistance:10.60K ohms
Inductance:6.40 mH
Peak Current:7.2 amps
Old 09-16-2020, 08:05 PM   #3
JSeery
JSeery's Avatar
This says it come in both 1.5 and 3.0 ohm versions, so be sure you know what you are getting.
PerTronix 40011 Flame-Thrower 40,000 Volt 1.5 ohm Coil
40,000 volts
Available chrome plated or black for that stock look
For use with inductive ignition systems
1.5 or 3.0 Ohm primary resistance values available
While it’s the perfect coil to go with the PerTronix Ignitor breakerless ignition, our 40,000 volt Flame-Thrower canister coil can benefit virtually any distributor type inductive system. Its higher voltage allows largerspark plug gaps for added power, smoother response and better fuel economy. These coils are internally resisted so installation and wiring is drastically simplified. Our oil filled coils offer great heat control for street driven vehicles, while our epoxy filled coils provide superior winding support for high vibration environments in off-road vehicles and boats.
I don't think it will output any more voltage than the plugs require under a given set of conditions. Increasing the voltage about what the compoents are designed for will lead to arcing. So I would stick with the stock plug gap.
Old 09-17-2020, 07:19 AM   #4
Frank Miller
Frank Miller's Avatar
Any coil will work on any car. The key is knowing how much voltage is fed to it and the condenser needs to be matched. Igniton systems are simple. You have a coil, points (switch) and condenser. The coil switching on an off creates the spark. The condenser controls arcing at the points. Too big or small of a condenser will cause the points to pit to one side of the other depending on whether the value is too big or small.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 09-17-2020, 06:39 PM   #5
47Monarch
47Monarch's Avatar
Thanks to all that answered I know it is a 1.5 ohm coil and should be 3ohm so do I need a different coil resistor or what my knowledge of electricity is about the same as brain surgery as far as I know distributor is stock again thanks for everyone's input
Old 09-17-2020, 06:46 PM   #6
Phil Gillespie
Phil Gillespie's Avatar
With a 12v system you will need 3 ohms so you will need to add a 1,5 ohms resistor to give required 3 ohms total which will then give approx 3 to 3,5 amps current draw to coil input.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 09-18-2020, 05:47 PM   #7
47Monarch
47Monarch's Avatar
I still have 6 volt positive ground system
Old 09-18-2020, 09:52 PM   #8
JSeery
JSeery's Avatar
Then just connect it up directly (no resistor). Power from the ignition switch to the (-) terminal on the coil and the (+) terminal to the distributor.
