Old 08-19-2020, 07:02 AM   #1
Habusailor
Habusailor's Avatar
Default Transmission change
If I go from automatic to 3 or 4 speed manual what is an easy fit for a newer tranny that will volt up to a 312 on my 57?
Habusailor is offline   Reply With Quote
Old 08-19-2020, 07:07 AM   #2
Ford blue blood
Ford blue blood's Avatar
Default Re: Transmission change
Go over to 57fordsforever, there are a bunch of folks that have done that swap there. Don't need to be a member to look and see the pictures that some have posted.
But generally speaking you will need the bell, fly wheel etc. and early (60s & 70s) three and four speeds have the narrow bolt pattern on the bell.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 08-19-2020, 08:23 AM   #3
51504bat
51504bat's Avatar
Most of the Ford top loader full syncro 3 speeds and 4 speed trans as well that I've seen were drilled with both the narrow and wide Ford pattern. When I was in HS I had a T-10 4 speed that I installed in a '65 Falcon that was drilled with both patterns as well.
Old 08-19-2020, 09:17 AM   #4
darrell
65 up will have both patterns
darrell is offline   Reply With Quote
Old 08-19-2020, 10:23 AM   #5
Ole Don
Ole Don's Avatar
If you truly enjoy driving the old car, and plan to put on some miles, step up to a five speed. Yes. they cost more, and require an adaptor, well worth the cost and work when you row through the gears and run 70 at 2200 rpms.
Ole Don is offline   Reply With Quote
Old 08-19-2020, 10:31 AM   #6
rotorwrench
rotorwrench's Avatar
The transmissions will likely be the easy part to find. The clutch & bell housing may be more work and a person will have to decide whether they want column shift or a floor shift. An electric overdrive set up was still available up into the 60s like the T85 with the R11 overdrive. This will give 4-speeds forward and 5 or 6-speeds if a person split shifts. I like the overdrives but some prefer the floor shift 4-speed for more off the line performance. Any of them should be relatively easy to find but the bell housing and clutch will take you a while.
Old 08-19-2020, 08:20 PM   #7
paul2748
paul2748's Avatar
Y block standard bell housing are relatively easy to find. If you don't already belong to Y-blocks forever you might join and look for it. The flywheel may be the hardest to find. Go for one with a 11 inch clutch.
I put an early top loader (single, old pattern) in my 54 behind a 312. It went fairly easy but does require some mods. Look for a falcon tailshaft as it has the shifter way up front for seat clearance. A good source for info and parts on a toploader is David Key.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-23-2020, 07:40 PM   #8
Gene F
Gene F's Avatar
I hear hanging that 3rd pedal in there is no fun.
I'd think it would be cool in my 57, but don't want my car torn down for a year to do it (Retired but went back to work). Every time I hire something done I need to do it over again it seems like. I'd opt for the 5-speed since my car has the factory optional taller gear in it. At 70 MPH my car is turning like 3,000 RPM.
Old 08-23-2020, 09:07 PM   #9
bobss396
bobss396's Avatar
The under dash work is tough and that assist spring is a fun job. Look on eBay, you can probably find a set of pedals. I almost went 5-speed on mine but would have had to do some floor work on it.
bobss396 is offline   Reply With Quote
Old 08-23-2020, 10:55 PM   #10
51504bat
51504bat's Avatar
Don't know about the assist spring in a '57 but when I was in HS I changed my '65 Falcon from an automatic to a stick. The assist spring install took me the best 2 out of 3 falls. But I somehow was able to get it hooked up with only a minimal amount of blood shed and ample amount of 4 letter words. Fast forward 10 years or so and a mentor and boss did the same conversion on a '65 Ranchero. He stretched the spring on the bench by inserting washers between the coils. When he stretched it sufficiently he hooked it up and started removing the washers. I drove it several months later and was surprised when I pushed in the clutch and a washer dropped from under the dash.
Old 08-24-2020, 02:50 PM   #11
hotrodart
hotrodart's Avatar
You might want to change out the
I did this swap (many years ago) and found it to be quite easy and straight forward. I bought a parts car and simply swapped over all the needed parts, and scrapped the remains......clutch pedal,linkage, etc. I used a floor shift rather than fiddle with the steering column, but I could have swapped that also. You might want to change out the rear gears for a bit easier driving.
hotrodart is offline   Reply With Quote
Old 08-24-2020, 06:17 PM   #12
56sedandelivery
56sedandelivery's Avatar
First car I bought was a 57 Fairlane. Came with auto but said the hell with that and got a change over from a wrecking yard. They were plentiful then. Was easy swap other then getting the auto out. But hey for a 19 year old good experience. Problem then way immediately went to performance modding it. When I stuck the Hay clutch in started blowing the three speed all the time. Too much grab I guess. Anyway got reeeeel good at rebuilding three speeds. Lol Great times
56sedandelivery is offline   Reply With Quote
Old 08-24-2020, 08:16 PM   #13
paul2748
paul2748's Avatar
The four speed that I installed went in an automatic car. I got all the stick parts (Z bar, pedals,linkage, etc) from a guy that went the other way. I found out that the only things you need to change as far as the pedal was adding the pedal itself and changing the bolt that holds the two pedals to the brace, so I didn't have to change the brace. The hard things to find are the standard shift plates that go around the steering column. I don't remember any particular problem with the spring, but I did this 15 years ago.
When working under the dash on this kind of job, remove the front seat
48 Ford Conv
56 Tbird
54 Ford Victoria
