Old 09-13-2018, 10:27 PM   #1
daren007
Default Model A clutch
Is there a source for model A clutch parts. I have one that is in real nice condition however it appears the throw out bearing must have had issues as the fingers are worn excessively. Are new finger available.
Daren
daren007 is offline   Reply With Quote
Old 09-14-2018, 02:03 AM   #2
Christoph
Christoph's Avatar
Default Re: Model A clutch
While driving, there should not be contact between bearing and fingers.
Make sure you have some free play in the clutch-pedal before there is some drag.
I doubt you will find new fingers to fit your plate.
I got 3 (Model-A) pressure-plates and all parts are different (not interchangeable)
Get a new throw-out-bearing, a new pressure-plate and follow Tom Endys
suggestions
Have fun
Chris
Christoph is offline   Reply With Quote
Old 09-14-2018, 08:05 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
You "might" get a lead by calling a local Truck Repair Shop & ask, "Who rebuilds your CLUTCHES"?
Bill Smooth
"THE ASSISTANT GURU OF STUFF"
Old 09-14-2018, 01:52 PM   #4
100IH
What Bill said. Frequently small parts of assemblies are only available to rebuilders who have accounts and stock parts.
100IH is offline   Reply With Quote
Old 09-14-2018, 02:15 PM   #5
F.M.
Daren
Berts in Denver will have many good used ones..
F.M. is offline   Reply With Quote
Old 09-14-2018, 03:31 PM   #6
WHN
I would get a new clutch. Why take a chance on something as important and hard to get out as a clutch.
There not that expensive.
Old 09-14-2018, 03:44 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
I recommend Bratton's for clutch replacement parts. They have the disc with the tabs that hold the springs in place. The other venders do not. https://www.brattons.com/clutch-disc.html
Old 09-14-2018, 05:39 PM   #8
1931 flamingo
1931 flamingo's Avatar
Fort Wayne Clutch or any of the above.
Paul in CT
Old 09-14-2018, 06:15 PM   #9
Russ/40
Russ/40's Avatar
Ditto as to Fort Wayne. They have the proper spring shrouded disc.
Old 09-14-2018, 07:53 PM   #10
Y-Blockhead
I don't know, the one in their picture doesn't look like it...
Old 09-14-2018, 11:24 PM   #11
Chris Haynes
Chris Haynes's Avatar
I have NOS Genuine Ford Model A Clutch disc and pressure plate. $75.00 plus the ride.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 09-15-2018, 12:41 AM   #12
Clem Clement
Clem Clement's Avatar
change the pilot bearing as well.
