Old 09-16-2016, 03:24 PM   #1
mill48
mill48's Avatar
Default 1928 Ford Model A aftermarket wiper
Hi everyone. I just bought an after market wiper kit (See image) for my 1928 Model A two door coupe. This kit came without instructions. There seems to be mounting holes on the windshield frame, but I am new to the Model A world and I am not sure how to install this kit. Is anyone on here familiar with this unit and can help with installation instructions?
The image is at this link: http://www.macsautoparts.com/ford_mo...tor-cover.html
mill48 is offline   Reply With Quote
Old 09-16-2016, 03:46 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: 1928 Ford Model A aftermarket wiper
hopefully someones converted your car to 12V negative ground first...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-16-2016, 04:21 PM   #3
wrndln
I agree with SeaSlugs, you better have a 12V negative ground system in your model A when you install the aftermarket wiper. Stock model A's have a 6v positive ground. Also, it appears the mounting of the wiper is going to be a real pain. The wiper from Mac's doesn't look anything like the wiper than came on a model A. 1928 model A coupes came with Owen-Dyneto (OD-C1) wipers that had mounting arms that fit in the holes in the windshield. The wiper wire is also a pain to install from the terminal box up the passenger side A pillar and across the top of the windshield. Grounding the wiper is also a problem sometimes, as only the power wire is connected to the wiper and the wiper relies on the chassis to provide the ground. I have a 28 model A coupe that has a OD-C1 wiper.
Rusty Nelson
Old 09-16-2016, 05:44 PM   #4
1931 flamingo
1931 flamingo's Avatar
I believe that's a one size fits all and if installed I don't think the windshield can be opened. FWIW
Paul in CT
Old 09-16-2016, 07:52 PM   #5
mill48
mill48's Avatar
It looks like it would be installed from the inside on the windshield frame. The vehicle is 12V negative ground.
Old 09-17-2016, 02:37 PM   #6
Dale
I just installed the same 6v wiper on my 29 PU, only so I could get CHP certified vin insp. It certainly won't wipe much rain. It was about a 30 minute job, went in the panel above the windshield, wire down the driver side post, switch ibeside motor. Windshield opens fine.
Dale is offline   Reply With Quote
Old 09-18-2016, 07:16 AM   #7
mill48
mill48's Avatar
Can you share installation instructions?
Old 09-18-2016, 09:44 AM   #8
Dale
Used the factory indents to drill the hole
Old 09-18-2016, 10:19 AM   #9
mill48
mill48's Avatar
I got that. I received a kit with no installation instruction, assemble, wiring, nothing. Do you have any?
Old 09-18-2016, 11:03 AM   #10
Dale
This is all that was in the box. No need to google Vintique.
Old 09-18-2016, 01:22 PM   #11
mill48
mill48's Avatar
Thanks. There was no diagram in my box. Thanks so much.
