Old 03-03-2016, 12:34 PM   #1
41plym
Default hinge pin removal
I bought a set of mirror's that fit on the top door hinge.
Any secrets for removing the pin with out damaging anything?
41plym is offline   Reply With Quote
Old 03-03-2016, 12:40 PM   #2
silversink
silversink's Avatar
Default Re: hinge pin removal
I ground down the screw of a c clamp and use a socket on top to drive out the pins
Hotrods don't have valve covers
silversink is offline   Reply With Quote
Old 03-03-2016, 12:50 PM   #3
CarlG
CarlG's Avatar
I have used this tool to remove the hinge pins a number of times. (available from most of the vendors)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-03-2016, 12:58 PM   #4
Mitch//pa
If the tool does not work drill them out. If you drill 1/4 in from each direction they will punch out with a hand punch
Old 03-03-2016, 12:58 PM   #5
VFRhugh
VFRhugh's Avatar
A couple of months ago I installed a hinge mount outside rear view mirror. Like everything else I've done it was a bigger job than you'd expect. After a little hammering it was obvious the old pin had worn a ridge that I couldn't overcome with brut force. Had to remove the door to drill each end enough the separate the hinge. Drilled out the remaining old pin using my drill press.
VFRhugh is offline   Reply With Quote
Old 03-03-2016, 01:55 PM   #6
V4F
V4F's Avatar
it can be a SOB , but drilling is good . if you beat on them to hard I would be afraid of hinge sag
V4f
V4F is offline   Reply With Quote
Old 03-03-2016, 02:36 PM   #7
Fred K-OR
Fred K-OR's Avatar
Mitch, wish I had known your advise when I took my 29 door hinges off. I drilled all the way and it was a pain.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 03-03-2016, 03:33 PM   #8
SSsssteamer
SSsssteamer's Avatar
I usually drill the door hinge pins out using a 7/32 " drill bit. When I am just about two thirds of through, I will put a drift punch in the hole and the old pin after a few taps will usually fall out onto the floor. In order to drill up close to the door, I use my right angle electric 1/4" drill. After this tedious drilling operation, I have always been able to go back to using the stock diameter door hing pins again.
SSsssteamer is offline   Reply With Quote
Old 03-03-2016, 03:39 PM   #9
Sunnybrook Farm
Sunnybrook Farm's Avatar
I don't think Ford ever planned on those pins coming loose, just take your time as it will mess up.
Sunnybrook Farm is offline   Reply With Quote
Old 03-03-2016, 06:20 PM   #10
Big hammer
I fought for hours removing hinge pins. I took a break went to tractor supply store, bought a air hammer, ground down one of the tools that came with it, smaller than the door pin.
Pulled the trigger and the hinge pin jumped out so high and fast I lost it. Best 20$ I ever spent!
Old 03-03-2016, 06:38 PM   #11
Redbird
Redbird's Avatar
I just added a right side mirror. I inserted a punch from the bottom and out it came. Lucky I guess.
Redbird is offline   Reply With Quote
Old 03-03-2016, 06:54 PM   #12
pgerhardt
pgerhardt's Avatar
For a month I gave mine a shot of Kroil every time I passed by the car. Then I used the Bob Drake hinge pin removal tool (picture) I got on E-bay. With some squeaking noise they came out.
pgerhardt is offline   Reply With Quote
