09-24-2023, 06:21 PM | #1 |
Spark Advance Level problem
My spark advance lever has always been rather stiff to operate but now it hardly will move at all. Has anyone had this problem and does the steering column need to come out to fix it?
09-24-2023, 06:51 PM | #2 |
Re: Spark Advance Level problem
Have you provided it with any lubrication?
09-24-2023, 06:58 PM | #3 |
Where do lubricate the spark advance lever? I don’t see the spark lever as a required lubrication point and there doesn’t appear to be an obvious place to lubricate.
09-24-2023, 07:50 PM | #4 |
First the top bushing on the steering column is made from pot metal which will swell with time clamping on to the spark & throttle levers. Don't use WD-40 but rather a graphite lube same as for lock cylinders.
Drip some at the very top of the lever were it enters the top bushing, just at the quadrant. You could spray some 'rust buster' oil up the shaft under the spark & throttle lever springs. Let the chemistry work, be patient. |
09-24-2023, 09:45 PM | #5 |
Make sure the top plate in the distributer is free to move easily and a light grease in the groove won't hurt.
09-25-2023, 03:49 PM | #6 |
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 09-26-2023 at 05:04 PM. Reason: Corrected typo. |
09-25-2023, 05:20 PM | #7 |
Nakimar nice how-to. People spout off this and that on here, but never give the proper information. Thanks!
09-25-2023, 06:21 PM | #8 |
Gene, Every post in this thread was on spot and helpful. Didn't need the comment.
09-25-2023, 06:23 PM | #9 |
Yes, they were. I did not mean this thread. Sorry J
09-25-2023, 07:20 PM | #10 |
Gene, you are correct as far as some threads go. If they turn a corner then we all should make that observation.
09-26-2023, 06:15 AM | #11 | |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
09-26-2023, 08:01 AM | #12 |
Thanks all for the good responses, especially the detailed instructions from nkaminar. I will give that a try.
