hello
i have been working on my brakes i am replacing the bearings on the frt. the hub inner bearing seal i can not get it off the backing plate,spindle . what it the best way to remove the old one thank you kevin 1930 tudor |
Probably really don't need to replace it
Just clean it all up and, you should be good seeing that its just something to keep the dust and dirt out of the bearing. Sent from my iPhone using Tapatalk |
Take out the 4 bolts and it should come right off, unless caked with grease and grime then you may need to pry it off.
I know the voices aren't real but damn they have some good ideas! ![]() |
thanks for the help
kevin |
Clean of all the excess grease adnd dirt , then pry it off with a screwdriver. ken
If the seal isn't rusted in...
After you pull the drum reinstall the nut on the end of the axle, then place the drum over that so the nut will catch the seal, then give it a good pull. |
#8 | |
![]() Quote:
Actually, it's more of a retainer rather than a seal.
Play it again Sam. |
After reading this thread I think three different parts have been mentioned
and I'm not sure which one the OP was referring to. |
#10 | |
![]() Quote:
What's sad is I just packed the front wheel bearing about a month ago...and I still brain-farted. To age or not to age, that is the question...LOL. |
hello
in bob's photos it is the one on the left kevin |
