10-26-2019, 05:01 PM | #1 |
PA old time drag with question
Friend and I went today. Very cool, mostly flatheads and old bikes racing
I’ll post pics. The question is: is this a newer engine with older heads or can you convert crab or helmet to this?
Thanks Andy 1952 F1 |
10-26-2019, 06:51 PM | #2 | |
Re: PA old time drag with question
Andy...It could be either, but I'd guess this one is a '49 or '50 with early heads and '42-'48 fan set-up . DD |
10-26-2019, 07:29 PM | #3 |
Looks to be a 8BA block with 59AB heads....Cam might have to be replaced to convert to crab or helmet....
10-26-2019, 09:22 PM | #4 |
Andy, love your pic of the engine....and the distributor....would be a dream to access and work on. Where in PA were the drags?
10-26-2019, 10:08 PM | #5 |
"A" heads 39 to 41
10-26-2019, 10:38 PM | #6 |
10-27-2019, 04:43 AM | #7 |
Allentown
10-27-2019, 04:46 AM | #8 |
Thanks guys. I wasn’t aware you could convert an early block ton this type of distributor
10-27-2019, 11:03 AM | #9 |
10-27-2019, 11:42 AM | #10 |
It’s the distributor which is weird with old heads.
Either they converterd the crab / Helmet to use a later model distro or they used older heads on later model flathead. Which I doubt would give more horse power for drag.
10-27-2019, 12:09 PM | #11 |
i did a conversion once, by simply swapping a late cam to an early block.. needed a front cover and obviously the distributor.. most difficult part was keeping the dizzy from moving.. which I accomplished with a simple set screw in the timing cover.
Pennsylvania has two seasons. Hershey week, and everything else https://sites.google.com/site/eastcoastwoodies/ |
10-27-2019, 12:36 PM | #12 |
I did the same thing with the heads.
10-27-2019, 01:57 PM | #13 |
You can install early heads on late blocks and visa-versa (24-stud). The only real difference is the water coolant passages which is a fairly simple modification.
10-27-2019, 02:17 PM | #14 |
The alternator mounting is kind of scary....
