Old 03-05-2021, 08:01 PM   #1
Standing Elk
Default Choke
So, just curious as to how, if having to hand crank my A, how do you go about closing the choke from outside the car? The model t had a choke rod that came out the right front below the rad. But guess I never knew how to choke the A while hand cranking. A close pin around the choke rod maybe?? Thanks
Standing Elk is offline   Reply With Quote
Old 03-05-2021, 08:14 PM   #2
Curtis in MA
Default Re: Choke
Cloths pin
Curtis in MA is offline   Reply With Quote
Old 03-05-2021, 08:14 PM   #3
Jerry in Shasta
Jerry in Shasta's Avatar
Default Re: Choke
String a piece of hay wire from the eye on the choke lever through the radiator, pull the wire to close the choke.
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 03-05-2021, 08:21 PM   #4
1955cj5
1955cj5's Avatar
Default Re: Choke
Here is a picture of the choke lever eye...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 03-05-2021, 08:53 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Choke
I keep this wire under the seat i found it along the side of the road in time of need,because it is temporary i open the hood to use it, i hook it in the empty hole in the bottom of the choke lever
Old 03-05-2021, 09:55 PM   #6
Synchro909
Synchro909's Avatar
Default Re: Choke
Originally Posted by Curtis in MA View Post
Cloths pin
Clothes peg.
Old 03-06-2021, 11:09 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Choke
Here's my tip:
Bob Bidonde
Old 03-06-2021, 12:00 PM   #8
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Choke
Cloths pin
Originally Posted by Synchro909 View Post
Clothes peg.
Pretty humorous when you correct someone and then get it incorrect.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-06-2021, 12:16 PM   #9
Gene F
Gene F's Avatar
Default Re: Choke
My rod has a gromet on the bottom of the gas tank that kind of holds it. I seldom use my crank. Maybe in the barn, at the start of spring when I don't wanna drag the battery down any more than I have to, till I get a charge on the battery. Besides, I usually use my foot and kinda jump on my hand-crank. My engine is pretty still, and I'm not thta big of a guy.
Been my experience I don't need the choke plate to be dead closed. I open my GAV a bit too. Once it fires I can retreat to the drivers compartment and smooth everything out.
The wire...yeah I guess you could, but I'd be inclined to hold it around the radiator shell. My radiator cost $585 plus shipping.
Old 03-06-2021, 06:57 PM   #10
1crosscut
1crosscut's Avatar
Default Re: Choke
Leave the key off, set the choke and pull up on the hand crank a couple of times.
Push in the choke, turn the key on and pull up on the hand crank a couple times to start it.
Oh... and don't forget to turn on the gas first.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-07-2021, 11:27 AM   #11
WHN
Default Re: Choke
Old high school trick. Two guys in back giving the car a push. Pop clutch, starts right up.
Old 03-07-2021, 12:23 PM   #12
rocket1
Default Re: Choke
Cloths pin
clothes-pin LOL
rocket1 is offline   Reply With Quote
