Old 12-05-2021, 06:43 PM   #1
Ten1nis
Ten1nis's Avatar
Default B carburetor leak
Recently, I was left along side of the road with a dirty carburetor. After cleaning it with carb cleaner and blowing it out with an air compressor it has my engine running better than ever.
Unfortunately, I have a fuel leak somewhere on the inside of the carburetor, as gas is leaking from the throat of the carb. I replaced all the Zenith B carburetor with new gaskets from Sniders. When I put the car away I always close the in-line valve and run the engine until it quits. Any ideas?
Ten1nis is offline   Reply With Quote
Old 12-06-2021, 11:28 AM   #2
AL in NY
AL in NY's Avatar
Default Re: B carburetor leak
Your float valve is bad or your float level is set to high. Check both.
AL in NY
AL in NY is offline   Reply With Quote
Old 12-06-2021, 02:52 PM   #3
Herb Concord Ca
Do what Al says.
Herb Concord Ca is offline   Reply With Quote
Old 12-06-2021, 11:11 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If your main and cap jets ( the two sticking up in the middle of the carb) don’t have a concave tip, then capillary action will cause them to leak. By the way, you didn’t say when it leaked.? When it’s off and the fuel shut off is off.
