Old 08-07-2021, 10:41 PM   #1
hardtimes
hardtimes's Avatar
Default Gas tank conundrum/help.
I have gas gauge out.
Problem is, the TANK threads are gummed badly with some “sealer”.
Need suggestions on how to get the tank threads clean…..without all the sealer ending up inside the tank !
Or should I just try to reseat the gauge with the crud still there ?
Old 08-07-2021, 11:41 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Gas tank conundrum/help.
I'd remove the sealer. Have you tried lacquer thinner?
Old 08-08-2021, 12:21 AM   #3
jb-ob
After lacquer thinner, go nuclear, urethane reducer.
jb-ob is offline   Reply With Quote
Old 08-08-2021, 04:28 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Depending on the sealer used, lacquer thinner is not going to faze it. You will need to use a thread cleaner or chaser to ‘cut’ the sealer out.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-08-2021, 06:34 AM   #5
nkaminar
nkaminar's Avatar
Dremel wire brush may work. They shed wires so be careful to clean up afterwards with a shop vac.
Old 08-08-2021, 08:02 AM   #6
Bob from Northport
Bob from Northport's Avatar
Have someone hold a shopvac near the work area as you clean with a small circular wire brush or dental pic. Should do the job.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 08-08-2021, 09:39 AM   #7
Ruth
Be careful using a shop vac around gas fumes!!
Ruth
Old 08-08-2021, 10:09 AM   #8
Tom Wesenberg
That's for sure! I quit buying them because they shed all the wires before I can do just one job.
Old 08-08-2021, 10:31 AM   #9
katy
katy's Avatar
Ditto,
How about a fitting for the gas cap opening and use low pressure air into the tank.
Old 08-08-2021, 01:57 PM   #10
mleder
I would run a string thru the opening and catch it from the inside. Once caught I would either find a rubber stopper or have some one cut me a cone shaped form on a wooden dowel on a lathe. I would thread an eye screw into the stopper and pull it into place closing the opening. Next I would find a dental hygienists set of picks and attack the coating.
mleder is offline   Reply With Quote
Old 08-08-2021, 02:35 PM   #11
J Franklin
J Franklin's Avatar
Unhappy Re: Gas tank conundrum/help.
Anyone with a good tank contemplating using a sealer should read this thread!
Old 08-08-2021, 04:18 PM   #12
hardtimes
hardtimes's Avatar
Yeah, I’m guessing that the sob (“restorer”) that created this mess did not have a clue, or care, what he had done !!
I’ve been thru A tank restoration and gas gauge repair thru the decades. This is a worst/first for me.
NOTE:
This tank has a little fuel in it yet…. EVEN IF IT ONLY HAD FUNES,
DO NOT USE anything that uses electricity and/ or can make a spark… around this tank.
May be the LAST thing you ever do in this life !!
If this has to be explained to anyone… well !!!
Old 08-08-2021, 04:22 PM   #13
hardtimes
hardtimes's Avatar
Take a close look at an A tank screw thread opening. There is threaded area…. AND NOTHING ELSE !
In other words, no plug holding room, at all !
Old 08-08-2021, 04:34 PM   #14
hardtimes
hardtimes's Avatar
Originally Posted by katy View Post
Ditto,
This idea worth giving thought.
I tried using a long nozzle , on air hose. Bent nozzle to point to gauge opening… to blow loose stuff into car.
Might work if I can get help operating air hose. Not possible for one person ( me) operation.
However, this may be only viable method…. To keep junk from going into tank.
This tank is with perfect paint, and clean inside. Hate to have to remove it, as that will cause a mess.
Old 08-08-2021, 04:42 PM   #15
hardtimes
hardtimes's Avatar
NO WIRE, no sparks= no BOOM !!
I agree about them ‘throwing’ wire.
Ever had such wire(s) … stick in your face and arms.. yikes… I have not fun !
ALWAYS wear face /eye protection !!
Old 08-08-2021, 04:51 PM   #16
hardtimes
hardtimes's Avatar
This is first idea I had also. Then thot… where would one get such a chaser/thread cleaner…for this specific job ??
I thot that … maybe taking/using a discarded old gauge threaded part, use with cleaner, etc… screw in out to break up some.
Keep in mind the goal…. To NOT get any junk in tank.
Old 08-08-2021, 05:10 PM   #17
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If you get a little in the tank, flush it out!
Old 08-09-2021, 05:52 AM   #18
BRENT in 10-uh-C
Just make it for the ones unavailable. Cut slots into the threads perpendicular to the thread direction using a jeweler's file. Whatever you get inside the tank can be flushed out easily since it is not behind the baffles.
BRENT in 10-uh-C
Old 08-09-2021, 08:30 AM   #19
nkaminar
nkaminar's Avatar
The rotating brushes with the brass wires will not spark.
I did not thing about the fumes when suggesting a shop vac. Probably a bad idea to use the shop vac.
Old 08-09-2021, 09:47 AM   #20
Dennis Pereira
Dennis Pereira's Avatar
A tooth brush and acetone might do the job .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
