03-04-2021, 12:07 PM | #21 |
Re: Adding a Coolant Overflow Tank
If the level in the top tank is below the input to the radiator from the engine, there will be aeration from the splash. If the bubbles make it to the water pumps, I don't know. If they do, the pumps will push them into the water jackets. We know that is not a good scenario.
03-04-2021, 02:27 PM | #22 |
OK, don't confuse me with facts, I have my mind made up.
It is a fact of life the heat expands, cold contracts.. Air intrainment in the coolant is not a good thing, the cooling effect of the coolant, regardless of what it is, is reduced with air in the system. After several recycles of the coolant via a recovery tank the air in the system is purged. The volume contained in the recovery tank does not add anything in the way of cooling, it just minimizes unnecessary coolant loss and removes air from the system. It is a fact that inexpensive plastic recovery tanks can be purchased from any major auto parts store, however, in many cases the space for a tank is limited, therefore a small 2" vertical tank is very desirable.
Bill.... 36 5 win cpe |
03-04-2021, 05:49 PM | #23 |
06-06-2022, 08:37 AM | #24 |
What brand tank/cap is everyone going with? My goal would be a solution that I could remove (I don't want to drill any holes). Pics would be great.
Thanks! -Brian
2009 BMW 135i, 2017 GTI S, 1990 SSP Notch (SOLD), Other Foxbodies (SOLD) |
06-06-2022, 07:59 PM | #25 |
just a heads up a lot of people use an of the shelf recovery tank designed for modern engines but dont realise that modern engines dont carry as much coolant as the average flathead given that an average flathead holds 20L [?gal] with an expansion rate of ten percent [water] from 20deg /100deg the volume of your coolant [water based as most are] will increase /expand by 2L[1 quart] you will need around 2quart [4L] volume in the tank being 1L reserve 2L expansion room and 1L freespace quite a sizable tank
06-07-2022, 05:56 AM | #26 |
06-07-2022, 10:23 AM | #27 | |
I would doubt that your '48 radiator, if it is original, has a neck that is designed for a pressure cap... From my experience, pressurized systems did not start to appear on vehicles until the mid '50's. My '53 Olds Super 88 has a 7.lb cap. My 56 Bird and '59 F100 both have 15 lb systems. Most modern radiator caps are pretty well generic, 7lb being the lightest, 15lb on the high side.
06-07-2022, 10:35 AM | #28 |
I'm using a WW1 aluminum canteen.
06-07-2022, 12:05 PM | #29 |
Good information thanks
06-07-2022, 12:08 PM | #30 |
Oh...you mean literally a canteen lol
I thought that was a brand
06-07-2022, 03:15 PM | #31 |
How far from the radiator can you put a recovery tank?
06-07-2022, 05:45 PM | #32 | |
Does anyone manufacture a 2" cap with a recovery valve? |
06-08-2022, 08:28 PM | #33 |
Thread Tools | |
Display Modes | |
