01-14-2019, 12:24 PM | #1 |
Need help with '38 WOODIE Window Regulator P/N
I've got a '38 woodie and I'm on a hunt for a passenger-side window regulator. When I originally built the car in the late '90's I used a Brazillian repop (after much fiddling and a little machine work). That regulator has failed and I'm looking for a Henry version to replace it.
I need a part number... I've come across a couple of sources and their prices are all over the map. The part number they're using is 78-702700. I'm afraid this may be for a standard passenger car. The woodie uses the open car cowl. Can anyone let me know what P/N I'm looking for? Thanks.
Seabright Hot Rods |
01-14-2019, 01:10 PM | #2 |
Re: Need help with '38 WOODIE Window Regulator P/N
I know for my 40, all the wagon only part #s start with 79 as body was type 790. It might be that in 38 wagons were still listed with the commercial bodies. As you guessed a number starting with 702 is for a regular passenger car, maybe a tudor. I don't have a 38 body book which would tell. Another 38 wagon owner will probably chime in.
I do know that for my 40, a 36 4 door rear winder is fairly close to the 40 front door and could be modified. |
01-14-2019, 03:38 PM | #3 |
What part do you need? There is a company called "This Ole' Coupe", www.thisolecoupe.com they might be able to make the gears for you. I believe I saw them at Hershey and they had sample gears. If it's the arms, they can be welded. Although if it's a Brazilian junk reproduction you may need the whole regulator. Finding a regulator for a '38 Woodie will be tough. There is someone advertising in the January issue of the V-8 Times also looking for a '38 regulator.
01-14-2019, 07:42 PM | #4 |
81A-790 RH used 48-792700 so do the 35-38 wagons 48-792701 is the LH
There is a very similar regulator 48-724400-A with what appears as different with bends in the arms. gears are most likely the same |
01-14-2019, 11:36 PM | #5 |
Terry,OH demonstrates the genius of Ford part numbers. Noting that the 38 wagon uses a 35 wagon number part tells you they were unchanged for the wagons from 35 to at least 38.
I recently talked to a Ford dealer parts man who said they are changing to a new system. The old system would probably be useless to the new cars anyway. |
01-15-2019, 12:56 PM | #6 |
01-15-2019, 05:01 PM | #7 | |
My Hardware and Trim book show a different handle used on the Wagons than the 1934 Roadster, though both mount with a center screw so it is possible the roadster handle ended up on at least one wagon. The 1933-34 roadster inside handle was used a long time, 1929-31 roadster, fordor phaeton, 1930-31 roadster pickup, 1933-34 phaeton, and 1928-56 panel truck rear doors. |
01-15-2019, 05:39 PM | #8 |
I know this is a long shot, but looking thru an old Bob Drake catalog he lists several window regulators. You might get close and match one up, or even mix and match to make a good one.
01-16-2019, 11:27 AM | #9 |
Try Regulator Roy (609) 828-8537 I got an NOS regulator from him last year at a fair price.
01-18-2019, 03:20 PM | #10 |
is this what your looking for? I just dug this out of my storage box. yellow script ford logo with part number 78-70200 as seen in pic 2.
01-22-2019, 02:08 PM | #11 | |
In searching I've found that the 78-70200 P/N is for a passenger car -- I'm thinking the Terry,OH number may be more accurate. After the Roadster Show I'll pull the door apart and take pics. Thanks.
