Old 08-02-2016, 06:34 AM   #1
tony starr
tony starr's Avatar
Default Accidently left ignition on
Hi all, I accidently left the ignition on my '30 A turned ON. I know I have a dead battery now. What other damage have I done? Burnt out coil? I'm yet to check it over... just wanting to know what to look for first. Thanks!
tony-starr.com
tony starr is offline   Reply With Quote
Old 08-02-2016, 07:00 AM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Accidently left ignition on
you could have aligned the planets so to speak with the points held open and everything is OK...if pints were closed coil could have some damage to it. SLOWLY charge the battery and see what happens.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-02-2016, 07:01 AM   #3
Mitch//pa
The Points could be burnt also if they were closed
Check the contacts
Old 08-02-2016, 07:08 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
It is possible to burn up the coil, points and other weak links in the ignition system, for me it was just a dead battery, ---the Optima, totally dead, I hooked up my old stupid 6V only trickle charger, 10 min later hand crank start, 20 min driving later starter would start the car, -----but I have seen coils split apart, and leaking
many modern chargers won't start charging a totally dead battery, they need to see a voltage that assures the charger that it is hooked up correct----old chargers many times don't have that system---by old I mean something before the 70s, I got my 6v only trickle charger from out of the trash in 1963
Kurt in NJ is online now   Reply With Quote
Old 08-02-2016, 07:56 AM   #5
C26Pinelake
Remember to charge the battery on Slow Charge! Wayne.
C26Pinelake is offline   Reply With Quote
Old 08-02-2016, 09:02 AM   #6
burner31
burner31's Avatar
Back in the day when men were men and booze still came in the inside vest pocket of your jacket, this happened a lot, just check things out and chalk it up to ...Opps
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 08-02-2016, 09:48 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
A guy in our club left his key on and it cooked the coil in 30 minutes. I seem to recall it being an aftermarket coil, which likely wasn't as good as an original Model A coil. As mentioned, slow charge the battery for several hours, then try starting the car. Circle the block several times or carry a spare coil until you are sure the coil will continue to work while hot.
Old 08-02-2016, 10:18 AM   #8
Nabco
Nabco's Avatar
Funny thing...after I read this earlier I went out to run some errands and I had done the same thing last night....left the ignition on.
She started right up, ran my errands, about 15 miles, turned her off 3 times and started right up every time.....I guess I got lucky!!!
1930 Deluxe Coupe
"Sister"
Nabco is offline   Reply With Quote
Old 08-02-2016, 10:25 AM   #9
Mitch//pa
Ck the points anyways.... And do a visual of the coil....
Old 08-02-2016, 10:29 AM   #10
Nabco
Nabco's Avatar
Thanks Mitch, what exactly should I look for?
1930 Deluxe Coupe
"Sister"
Old 08-02-2016, 10:49 AM   #11
Mitch//pa
Just make sure it doesn't look like it burned, or is leaking, the wiring looks kosher....Ck the points contacts for burning, dark discoloration, or pitting... A point file works good or like .. It's a good time to Ck the gap and lube the cam..
If the points are smoked replace them...
Maybe you got lucky and they were open
Old 08-02-2016, 10:51 AM   #12
mshmodela
mshmodela's Avatar
Mitch got it... My Dad always told me about that.... "DON'T LEAVE THE IGNITION ON, YOU'LL BURN THE POINTS" I guess his word never let me... I always double check I have my car turned off and ensure my battery disconnect is turned off..
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-02-2016, 10:53 AM   #13
Nabco
Nabco's Avatar
Thanks Mitch, took a look at the points and they look fine, I had actually lubed the cam and checked the gap on Saturday.
Everything looks good on the coil....
1930 Deluxe Coupe
"Sister"
Old 08-02-2016, 11:04 AM   #14
Jason in TX
Jason in TX's Avatar
If you want to take some fine fine sand paper or emry cloth and just slip it through the closed points to clean them, that never hurts.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 08-02-2016, 11:04 AM   #15
larrys40
Wow,
Now that's what I call a coil test! I load test my coils but not that long for sure!
Sounds like the FB boys ( Mitch, tom and gang) had you covered and if nothing else had a forced tune up to the points and ignition. It really stresses a coil to the max to discharge a full battery to it...
so just to be safe you might want to keep a spare known good coil in the car in case something happens down the road.
Happy "A" Motoring to you!
Larry Shepard
larrys40 is offline   Reply With Quote
Old 08-02-2016, 11:36 AM   #16
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
With a stone dead battery, in the country, with NO electricity or battery chargers, we'd just push it with a car, until the generator kicked in.
ONE Strong, Fast Mule can sometimes do it, in second gear. Just be SURE to use a LOOOONG chain, so you don't run him over, when it STARTS!!!
Bill Mulepower
"THE ASSISTANT GURU OF STUFF"
Old 08-02-2016, 11:53 AM   #17
Nabco
Nabco's Avatar
Originally Posted by larrys40 View Post
Wow,
Larry Shepard
Larry, just took her for another 7 or 8 mile ride, all good.....any symptoms I should watch out for indications something is going bad?
1930 Deluxe Coupe
"Sister"
Old 08-02-2016, 12:23 PM   #18
Patrick L.
Patrick L.'s Avatar
Sounds as though you're going to be OK and got lucky that the points were open. What are the odds ? [Never mind, cuz I'm sure someone will know them.]
Old 08-02-2016, 12:30 PM   #19
Nabco
Nabco's Avatar
Thanks guys....
1930 Deluxe Coupe
"Sister"
Old 08-02-2016, 01:23 PM   #20
Nabco
Nabco's Avatar
Just to make sure everything is ok I just took her for another 9 mile drive, no backfires, smooth idle at stop, no stalling, good acceleration...... It looks like I'm good....maybe I should buy a lottery ticket today!!!!
1930 Deluxe Coupe
"Sister"
Thread Tools
Display Modes
