Old 08-04-2020, 05:24 PM   #1
psavello
Post Clutch pedal adjustment for "play"
Am new owner of restored 1928 Model A Roadster. Clutch pedal has no play and I need to adjust to approximately 1-inch free play. Les Andrews Volume I (page 2-8) states placing "...small hydraulic jack under the clutch actuating arm." Does this mean under the "arm" itself as in his accompanying drawing on page 2-8? Or on the housing that surrounds the arm? And how does one know if the arm is raised enough to "...relieve tension on the pedal clevis rod?"
psavello is offline   Reply With Quote
Old 08-04-2020, 05:56 PM   #2
vernlee
Default Re: Clutch pedal adjustment for "play"
You want to raise the actuating arm until the tension is removed so you can pull the clevis rod pin , this will allow you to increase or decrease pedal free play by turning the clevis rod , I just did mine , didn't have to use a jack , I could move it enough by hand to remove the pin.
vernlee is offline   Reply With Quote
Old 08-04-2020, 05:59 PM   #3
rivcokid
rivcokid's Avatar
Psavello - I literally just went through this last week/weekend for the first time. The small arm is under tension. You won't get anything adjusted without the jack. Put the jack under the arm (not the housing) and lift it about 1/4 - 1/2 inch. That's all. Then you'll find that removing the cotter and clevis pins are relatively easy. Keep the jack there, though, because when you adjust the rod and try to realign it with the arm, it won't happen unless you have the arm jacked up a bit. Good luck!
rivcokid is offline   Reply With Quote
Old 08-04-2020, 06:00 PM   #4
psavello
Post Re: Clutch pedal adjustment for "play"
Thanks! I'll try without a jack. If I need to use one I'll figure out where to position it to relieve the tension.
Old 08-04-2020, 06:02 PM   #5
psavello
Thanks to rivcokid for detailed information.
Much appreciated. I now understand the "why" and the "how."
Certainly is GREAT to have FordBarn Forum for Model A autos!
Old 08-04-2020, 06:34 PM   #6
1930artdeco
1930artdeco's Avatar
Piece of advice. If you have the original arm it is cast and may break on you at some point, you will then lose the clutch. There is a modern steel arm that is produced so if you have to remove it for some reason consider using the modern steel version. Ask me how I know....
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 08-04-2020, 07:00 PM   #7
psavello
Thanks immensely to 1930artdeco for hint and heads-up about cast vs. steel arm. I will definitely look into this as a replacement.
Old 08-04-2020, 07:39 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Here is a picture of what Mike is referring to. Not fun driving home with no clutch.
