Old 06-11-2012, 04:13 PM   #1
estout81
Default dual carbs
Have a flathead with Edelbrock manifold, dual with 4.75 carb spacing. Current set-up is not working! Throttle sticking due to wore balls on throttle linkage. Using passenger side linkage. Carbs are "94's" without extended shafts.
Need advice on what parts I need and where to get them. Pictures would be helpfull. Quality is more important than price.
Thanks
estout81 is offline   Reply With Quote
Old 06-11-2012, 04:42 PM   #2
1952henry
1952henry's Avatar
Default Re: dual carbs
Ken CT or Charlie NY here on the 'barn can probably set you up with extended shafts and a quality driver's side linkage.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 06-11-2012, 04:49 PM   #3
uncle max
uncle max's Avatar
Drilled 303 stainless dogbone arms with double set-screws and swivels - Stainless interconnecting rod. Custom made, right here, when money doesn't matter!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
