04-17-2012, 08:39 AM | #1 |
Ford Script Valves
I have a set of Ford Script Valves and all but one are serviceable. Are they worth anything other than to put in an engine and run?
04-17-2012, 08:54 AM | #2 |
Re: Ford Script Valves
Without being 'cute' or sarcastic, "worth anything other than to put in an engine and run" means what? If someone is building a static display, they might have some value to that person however they would likely want an original box to go with them, --or if someone else has a partial set and is needing a couple replacements, yours may have some small value to them but for me personally if they are the original style, I feel the modern stainless valves that allow the use of a one-piece valve guide is much superior to run.
04-17-2012, 01:43 PM | #3 | |
The reason I'm asking is I have a use for 4 of the valves and was wondering if it would be better to keep them together as a set?. That diamond block I posted about a few days back is a good engine but is in need of a valve job, 2 of the exh valves are mildly burnt. Currently the engine for my A is at the machine shop getting sleeves, seats, etc. The condition of this diamond engine is such that with a simple valve job it will probably last years and certainly until I finish rebuilding the engine that goes in my A. By using 4 of these Script valves to replace the bad exh valves in that diamond engine I can get my A back on the road and take my time rebuilding the proper engine for it. There is a certain urgency in my wanting to get it back on the road again. I learned how to drive in this A and taught 3 of my 4 kids how to drive in it. Now it's the "Baby's" turn to learn. BTW I appreciate your comments. |
04-17-2012, 02:08 PM | #4 |
I haven't used the new type valve probably because I had a few sets of nos guides Put them in that B engine and go down the road!!! John |
