11-21-2021, 08:27 PM | #1 |
Head Label
Does anyone have a guess as the origin of the head shown in the attached picture? One stamping/label says "MADE N U.S.A" and the other one says "2-28-33".
Thanks: |
11-21-2021, 08:39 PM | #2 |
Re: Head Label
Could be any one of the various after-market foundries making replacement heads for the Model-A during the 1930's. Sears Roebuck, Montgomery Wards, Western Auto, etc. sold Model-A parts well into the 1960's.
11-21-2021, 11:38 PM | #3 |
Re: Head Label
Usually heads made after 1931 had these types of markings.
www.whidbeymodelaclub.com |
11-22-2021, 12:29 PM | #4 |
Re: Head Label
Just curious if it’s a high compression head?
11-22-2021, 03:14 PM | #5 |
Re: Head Label
my indication would be no as far as picture goes, But??
11-22-2021, 03:54 PM | #6 |
Re: Head Label
11-23-2021, 10:01 AM | #7 |
Re: Head Label
A compression check will let you know if the head is high compression or not. Add a little oil to the cylinders first to remove the rings from the picture. The stock head will produce about 50 psi and a high compression head about 90 psi.
11-23-2021, 11:24 AM | #8 |
Re: Head Label
Look at the front of the head, on the lip below the water outlet. Is there any markings on there?
11-23-2021, 01:41 PM | #9 |
Re: Head Label
No markings on the lip below the water jacket. Compression is around 50. So, unlikely that this is a high compression head.
11-23-2021, 07:29 PM | #10 |
Re: Head Label
Ford outsourced casting for the model A after regular production stopped and same with cylinder blocks. This is where the diamond blocks came in. They kept building the model A engines on a separate line till 1941 for agricultural products and industrial applications. The late B engines had the C head but even they eventually went out of regular production.
Most aftermarket heads were for higher compression applications. |
11-23-2021, 10:39 PM | #11 |
Re: Head Label
I have one just like it except mine says 43 I think instead of 33. It is a low compression stock model A head.
Mike
11-24-2021, 09:01 AM | #12 |
Re: Head Label
I had one of those, very similar looks & date. My Dad had told me once it was a higher compression head because the chambers were more heart shaped than round? I didn't really need it so I let it go.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
