02-28-2015, 08:16 PM | #1 |
21 stud bolt pattern - anyone have it?
I'm going to make a an aluminum honing plate for my 21 stud block. Does anyone have a drawing or locations for the stud holes? If you can help me out you'll save me a tremendous amount of time reverse engineering used parts.
02-28-2015, 08:22 PM | #2 |
Re: 21 stud bolt pattern - anyone have it?
And you don't have a head or head gasket to transfer from? (Doesn't have to be super accurate )
02-28-2015, 08:38 PM | #3 |
Because I'm going to use the plates for several things, I'm going to CNC profile the outline of the combustion chamber gasket edges into the plates and I want the bolt holes in the right locations. In this case for what I'm doing yes it does need to be accurate. An old ford drawing or similar to start with would be very helpful.
02-28-2015, 09:19 PM | #4 | |
03-01-2015, 02:43 AM | #5 | |
03-01-2015, 04:44 AM | #6 |
Can't help with dimensions, I'd transfer them from a genuine ford head. Mart. |
03-01-2015, 10:41 AM | #7 | |
If you have access to a "CNC" you should be able to probe the holes either in a head or a block. Not sure what type CNC mill you are using? Probing all the holes will give you accurate numbers/dimensions. Thanks, Gary in N.Y. P.S. We use our block-plate also as a fixture to "pin" the heads and gaskets to all the Flathead units we build. It makes for longer gasket life, keeps everything lined up, same scenario as the SB Chev's!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
03-01-2015, 11:49 AM | #8 | |
Nice work, that's very much what I have in mind. My VMC doesn't have a probe, I'd have to indicate the holes and contours in a sheetmetal gasket which sure seems like a problematic challenge to say the least, plus I'd have to trust the gasket I chose.
Would you be interested in sharing your data? I assume you have only the 24 stud pattern? If so, It would still help as a good starting point. Quote:
