10-30-2020, 06:48 PM | #1 |
Need pictures.
Looking for pictures of how the master cylinder is installed when changing to hydraulic brakes. Appreciate your help. 31 model A coupe.
10-30-2020, 08:16 PM | #2 |
Re: Need pictures.
Don't need hyd brakes..use stock set in good shape and add floaters ..going to a lot of work for little gain ..sc
10-30-2020, 10:56 PM | #3 | |
Re: Need pictures.
As has been said, a lot of work for not much gain, even a deficit if the car is not used much because hydraulics can seize up through lack of use.
10-31-2020, 08:26 AM | #4 | |
Re: Need pictures.
One must understand the difference between a brake rods and brake lines ! I do not consider my wifes 2015 a classic or a antique but her close encounter coming to a red light and bong brake pedal to the floor her quick thinking was emergency brake which is mechanical thats positive. A side from rust prone brake lines, she blew a brake hose. In my book, these hoses are no where the quality of real hydraulic hoses. |
10-30-2020, 08:28 PM | #5 |
Re: Need pictures.
10-30-2020, 10:26 PM | #6 |
Re: Need pictures.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
10-31-2020, 07:23 AM | #7 |
Re: Need pictures.
All the OP asked for was a picture, not opinions. Thousands of Model A's and 32-38 Fords have been converted to hydraulic with few of the problems always listed, Chevy and MoPar did it even earlier. JMO
Paul in CT |
10-31-2020, 07:31 AM | #8 |
Re: Need pictures.
I agree with your first sentence ! And have no comment on the last sentence.
10-31-2020, 08:33 AM | #9 |
Re: Need pictures.
10-31-2020, 08:33 AM | #10 |
Re: Need pictures.
Good Morning. I bought this A with hydraulic brakes on it. If it had A brakes I would have put Flat head Teds energize on it . I have two A with them an work great. This cars master cylinder was put on the rt side don’t as me why I don’t know trying to fix it right. Just trying to find out the best way. Thanks for your help.
10-31-2020, 01:36 PM | #11 |
Re: Need pictures.
Many mount the M/Cyl on the right side and use the original cross shaft to actuate it.
Paul in CT |
10-31-2020, 03:17 PM | #12 |
Re: Need pictures.
Thanks Paul. If anyone has pics of how they are mounted on the right side please post them. Or tell me how they are done. I appreciate your help.
10-31-2020, 04:00 PM | #13 |
Re: Need pictures.
Here you go.
10-31-2020, 03:32 PM | #14 |
Re: Need pictures.
Chris Haynes. I see you have an A with the master cylinder on the Rt side could you post more pics. Thanks.
10-31-2020, 05:19 PM | #15 |
Re: Need pictures.
Bob what size lines do you use. I think the ones on my car is 3/16th. Some one told they were to big.
