Old 03-25-2024, 04:54 PM   #1
48fordconv
Default 48 Ford Removing rear hub snap ring
How do you remove snap ring on 48 Ford Car, the ring that holds grease seal n rear hub, Thanks
48fordconv is offline   Reply With Quote
Old 03-25-2024, 08:08 PM   #2
Kube
Kube's Avatar
Default Re: 48 Ford Removing rear hub snap ring
PITA the first time. I use one thin blade screwdriver to move the end of the ring away from its seat. Then push another in the opening between the drum and ring that was created in "step #1".
Pry the ring away a little with the screwdriver and put yet another a little "further down the line.
Soon enough you'll be able to grasp the "loose end" of the ring with a locking pliers and pull it out the rest of the way.
Before reinstalling the ring, cut the "other end" in the opposite direction it is currently in so you may use a snap ring plier next time.
Old 03-26-2024, 06:04 AM   #3
flathead48
I always drill a small hole in one end before putting it in makes it easy to put a small screw driver in & pull it out.
flathead48 is offline   Reply With Quote
Old 03-26-2024, 01:37 PM   #4
coolcoupe
coolcoupe's Avatar
Did all 1940-48 rear drums have a snap ring ? I am replacing a rear drum that does not have a snap, is it just missing ?
coolcoupe is offline   Reply With Quote
Old 03-26-2024, 01:42 PM   #5
Kube
Kube's Avatar
It's missing.
Old 03-26-2024, 02:04 PM   #6
coolcoupe
coolcoupe's Avatar
Thanks Kube, will start looking for one !!
Old 03-27-2024, 08:09 PM   #7
coolcoupe
coolcoupe's Avatar
Well I found a old no good drum/hub to get 2 snap rings and it was a test of my patience but I did it !!! Thanks Guys
