Old 05-16-2020, 09:28 AM   #1
History
History's Avatar
Default Seems like there's not enough fuel
It starts great, idles great but when I hit the accelerator I can hear it sucking hard and while it doesn't backfire it's almost like it wants to. I had completely disassembled the carb and cleaned all passages last year. It ran great, accelerated great but there was no difference i could tell when I turn the (gav). You fellows helped me figure out that I hadn't cleaned the (gav) passage. I did that and now can tell a difference but it didn't perform as it had before. I'm not sure what's going on. I believe I have great flow to the carb, the inlet is not in too deep so that's not restricting. I'm not sure what to do, intake gasket? I'll try some starting fluid and see. It really ran great and now seems to be starving when I open it up.
I have a new valve at the tank and always close it and run the carb dry during shut down. I don't think the valve leaks any and the carb fills immediately when I turn the valve on.
History is offline   Reply With Quote
Old 05-16-2020, 10:14 AM   #2
eagle
eagle's Avatar
Default Re: Seems like there's not enough fuel
It does sound like carb issues, however ignition can do the same thing. Lift a plug wire/strap while engine is running, preferably in the evening when not so bright out, and observe the spark to the plug. Should be strong, steady, and blue. Just for reference, mine will spark to plug top at least a half inch, steady and blue. For checking an intake gasket, I think its easier to use an unlit propane torch. You can direct it around the gasket area without the carb intake sucking in the vapors. Also check carb to manifold gasket area.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 05-16-2020, 10:50 AM   #3
30 Closed Cab PU
Have you removed/installed the coil lately? If in backwards it may kind of work, but has a weak spark. It will look blue but is weak. In the above test if considerably less than half an inch - weak spark.
30 Closed Cab PU is offline   Reply With Quote
Old 05-16-2020, 11:55 AM   #4
History
History's Avatar
Torch idea is a good one, never considered it.
I have not touched the coil.
I'll check the gas flow one more time. Does anyone have an idea of what ten seconds of drawing gas through the line as it goes into the carburetor will get me? Pint? Does any one had a time figure to use?
Thanks for replies
Old 05-16-2020, 12:39 PM   #5
1931 flamingo
1931 flamingo's Avatar
Disconnect the line at the carb, turn on the fuel, you should get a steady, strong "piss" out of the line.
Paul in CT
Old 05-16-2020, 12:55 PM   #6
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Take out at least one plug and see if it is black and fuzzy. If so, clean the plugs.
Jacksonlll is offline   Reply With Quote
Old 05-16-2020, 05:25 PM   #7
History
History's Avatar
I did and they were black but not fuzzy, didn’t seem oily either. I did notice that if while I operated the throttle from at the carburetor and opened the gav it would smoke some and not if I almost closed it. It doesn’t seem to be flooding even when it smokes. I won’t be able to try anything until tomorrow or Monday as we are bringing our kids belongings home from college.
Old 05-19-2020, 07:37 AM   #8
chap52
chap52's Avatar
Might just be the carb mixture adjustment? Chap
chap52 is offline   Reply With Quote
