Old 02-18-2016, 09:14 AM   #1
JohnB15632
JohnB15632's Avatar
Default Installation fo Shell Lacing Question
I want to install the Shell Lacing on the radiator shell on my 1931 Model A Slant Window 4 Door Town Sedan.
The radiator brace rods also connect on the radiator shell, in the same area as the Shell Lacing.
My question is this. Do I bring the lacing up to the radiator brace supports, stop, and begin again on the other side? Or should I cut around the brace support and continue onto the other side?
Thanks!
JohnB15632 is offline   Reply With Quote
Old 02-18-2016, 09:18 AM   #2
wrndln
Default Re: Installation fo Shell Lacing Question
There are 2 pieces used for shell lacing, one on the left side and one on the right side. I think you are referring to the front hood rod support bracket riveted to the radiator shell verses bracket for the radiator rods. The radiator support bracket is not on the radiator shell. I am not a 30/31 person, but to my knowledge, there are two pieces use on radiator shells used on 28/29 radiator shells.
Rusty Nelson
Old 02-18-2016, 09:29 AM   #3
Red Ryder
The lacing is one piece, cut around the support.
Red Ryder is offline   Reply With Quote
Old 02-18-2016, 09:33 AM   #4
JohnB15632
JohnB15632's Avatar
Now I am confused!!! Which is it??????
Old 02-18-2016, 10:36 AM   #5
Dollar Bill
Dollar Bill's Avatar
Two pieces like wrndln and Don advised.It stops at the hood hinge support on both sides.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 02-18-2016, 11:59 AM   #6
art ebeling
art ebeling's Avatar
Here is a picture of my 1931. the lacing stops before the hood rod bracket at the top.
art ebeling is offline   Reply With Quote
Old 02-18-2016, 03:46 PM   #7
JohnB15632
JohnB15632's Avatar
Thank you guys for your help. I was able to get the right side of the shell lacing on the radiator shell today. I will get the left side done tomorrow or Saturday.
Thank you again.
John
Old 08-13-2016, 04:20 PM   #8
duke36
Another lacing ?. When installing the lacing, does the wider bead on the lacing face the polished shell surface or inside towards the motor as in the ebeling photo? Have seen it both ways. Also, made the rivet tool from a nut tack welded to an extra ch. lock pliers as per attached photo.
duke36 is offline   Reply With Quote
Old 08-13-2016, 08:49 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
I haven't done one in years, but I recall both beads being equal, as in no front or back side.
Old 08-13-2016, 10:41 PM   #10
Barber31
Barber31's Avatar
I'm glad you posted that handy tool duke36. I'll keep that in mind in a few weeks when I re lace mine.
Barber31 is offline   Reply With Quote
Old 08-14-2016, 09:41 AM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Anyone ever asked a question & wished they hadn't & just done it the way you wanted to?
Will you miss the "BEST OF SHOW" Trophy, IF your hood lacing AIN'T up to PAR?
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-14-2016, 05:19 PM   #12
J Franklin
J Franklin's Avatar
it would be interesting to look at a NOS shell to see the factory method. I picture it would be faster if the piece of lacing was die-cut and placed whole, one worker on each side riviting as it comes down the line.
Old 08-14-2016, 06:25 PM   #13
ModelAMike1930
ModelAMike1930's Avatar
The lacing on my coupe is cut out around the radiator support and looks good to me. I will be doing my pickup the same way. P.S. both 1930 models
ModelAMike1930 is offline   Reply With Quote
Old 08-15-2016, 10:07 AM   #14
duke36
there is an engine compartment photo in the '97 Judging Standards that appears to show the lacing cut at the top of the shell as in Art's photo. I saw a photo of an original '31 SW sedan that confirms the lacing installed in 2 pieces at that time.
