Old 07-13-2016, 01:00 PM   #1
Goldfinch28
Default Power steering problem
New aftermarket power steering setup on 56 tbird. Has bad chatter when returning to center position on steering wheel,also belt squeal on end stops. Is there adjustment for length of throw on ram no air in system hose route seems fine. Need help thanks goldfinch28
Goldfinch28 is offline   Reply With Quote
Old 07-14-2016, 09:36 AM   #2
Ole Don
Ole Don's Avatar
Default Re: Power steering problem
Belt squeal on both ends is normal. On most older cars, the owners manual says to turn to stop then release steering wheel a bit. Chatter on return tells me there is still air in the system. When you get the bugs worked out, the car will be a joy to drive. You will be finding a reason to go someplace.
Ole Don is offline   Reply With Quote
