Old 01-08-2014, 11:31 AM   #1
40Pickup
40Pickup's Avatar
Default Found a crack in the cylinder head.
A crack just in casting joint, probably an old freezing damage.
Has run for 6 years with no visible lekage. Maybe it has been prepared with Wondarweld!
Took engine 59A apart for overhaul and found this! Not funny!
/ Jorgen
40Pickup is offline   Reply With Quote
Old 01-08-2014, 11:35 AM   #2
Russ/40
Russ/40's Avatar
Default Re: Found a crack in the cylinder head.
Is that a commercially available pressure test plate, or did you make it?
Russ/40 is offline   Reply With Quote
Old 01-08-2014, 11:46 AM   #3
alan
is it actually a crack or is the casting pourus? If it is pourus it was probably sealed with sealer or rust from the inside. Did you clean the head ?
alan is offline   Reply With Quote
Old 01-08-2014, 01:26 PM   #4
40Pickup
40Pickup's Avatar
Did a drawing and waterjet cut it out.
/ Jorgen
Old 01-08-2014, 03:10 PM   #5
Bolts
Bolts's Avatar
How much pressure do you use for the test?
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
Old 01-08-2014, 03:35 PM   #6
40Pickup
40Pickup's Avatar
Did some cleaning, found the crack and did a pressure test, about 2.5bar/35lbs.
/Jorgen
