05-01-2022, 07:28 PM | #1 |
model a frame body mount ques
i am finding that some body/cowls do not line up with body mount bracket..from Steves frame data,,sept 18.1930 the body mount bracket was moved back 2 3/8 inches."frame assembly A-5005-D,,.so question:does this mean if the body/cowl mates with the prior dimension's ,,it was made prior to sept 18,1930....and ..and if the body/cowl mates with the body bracket,moved back 2 3/8 inches..the body/cowl was made after sept 18.1930???Hummmm....never knew body/cowl moved bolt holes to frame bracket ??thanks..charles..
05-01-2022, 07:33 PM | #2 |
Re: model a frame body mount ques
