08-23-2017, 10:23 AM | #1 |
Modern shocks on a 35 Ford
Any 35 ford owners using modern shocks? looking for the best kit available.
Thanks. |
08-23-2017, 10:47 AM | #2 |
Re: Modern shocks on a 35 Ford
i used the pete and jakes kit, it bolted on without any fuss, I liked it because the top of the shock is supported in double shear whereas other kits seem to mount them in single shear.
https://www.peteandjakes.com/parts/1...ont-shock-kit/ |
08-23-2017, 07:19 PM | #3 |
Yes I use the same on my 35 pickup along with the weld on rear mounts, if you use their anti swaybar as well you will turn your car into a new one! ; )
08-23-2017, 07:22 PM | #4 |
Yes P&J on my 36 pu 40k miles working good (front and rear) -36pickup
08-23-2017, 07:31 PM | #5 |
You can also use the Bob Drake kit for the front and rear.
08-23-2017, 09:58 PM | #6 |
08-24-2017, 02:48 AM | #7 |
the bolt/stud going through the bottom of the shock on the last pic makes it look like its sitting at an angle. I cant see how this bolt/stud can support a shock absorber safely give its only going through a small plate on one side of the shock.
08-24-2017, 06:46 AM | #8 |
This is an older post that gives some details on an adapter used on the rear of 35-36 Fords. This is what's on a '35 3w coupe that I own. Unfortunately some of the Photo Bucket pictures have been eliminated.
https://www.fordbarn.com/forum/showt...ghlight=shocks
08-24-2017, 10:08 AM | #9 | |
The angle of the shocks isn't ideal but there's stuff in the way of making his mounting the ideal 80-90 degrees. |
