Old 06-10-2016, 03:48 PM   #1
William Kelchner
William Kelchner's Avatar
Default 30 Original type dist
Anyone know the dimensions of the steel spacer which goes under the top plate and connects with pigtail? Brattons catalog page 79 item #20 on the exploded view. TIA Have a good weekend
Bill K
William Kelchner is offline   Reply With Quote
Old 06-10-2016, 04:44 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 30 Original type dist
I only have one out right now and I don't know if it's original or a repro part.
ID = .175"
OD = .408"
Thickness = .094"
This only brings the surface to the same level at the bottom side of the upper plate, so you will need to use the fiber insulation washer under the flag terminal.
Old 06-10-2016, 05:33 PM   #3
leo
leo's Avatar
William, I've spend a lot of time trying to find a supply of these washers on various web sites without any luck, it's an odd size and must be another one of Henry's exclusives for lack of a better word. If you want to buy some try A&L, they have them at 15 cents each otherwise you will need to have them made by someone.
leo is offline   Reply With Quote
Old 06-10-2016, 06:24 PM   #4
William Kelchner
Ok thanks for the info, appreciate it. Cheers
Old 06-10-2016, 06:54 PM   #5
C26Pinelake
Why would you spend a lot of time searching if A & L has them for 15 cents? Wayne
C26Pinelake is offline   Reply With Quote
Old 06-10-2016, 08:10 PM   #6
Brian T
Brian T's Avatar
Snyders have them by the dozens, A-12199-MB, Brattons do not sell them separate only in a kit, originals were fiber.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
